Vicki, I've tried the calcium and hard water deposit remover cleaner on my stone. At this point it doesn't seem you have much to lose. That's a bad build up. You may try white vinegar and baking soda. It makes a bubbly paste, and they should neutralize each other. Try one small square first, with a toothbrush, and see if it works. If so, wash it all off and let it dry before continuing w/the others. If it doesn't work, try the spray stuff meant for hard water and build up. Leave it on a few minutes and scrub. See how it looks after it's dry.
I think if it works, just use it this one time to get everything as clean as possible. After it dries thoroughly, apply your impregnating sealer. From there on out, use a cleaner meant for natural stone and try to stay on top of the stains.
Liz
