I see this topic has been gone over more then once but I was hoping for some opinions on possible substitutes as the Real thing is not practical here in Canada.
I checked my local Lowes, Rona, Home Depot no one carries this stuff Amazon.ca carries it for around $27+ $10 shipping, as I am doing a Kerdi membrane (actually Prova) kit with the pan and curb all I want is to do a few touch ups (The very top of the corner patches did not stay, I would like to use some on the curb and will also be building a niche without buying the $120 prefab foam board one) and $40 + shipping time for a few squeezes on the caulk gun is too much. I have looked and similar sealants made by Wedi, Durock, Nobel etc are not available here even on amazon. There is one by PROVAfor $20 but it says "Siliconized" which my research says is acrylic like what custom makes and is not recommended on this site ( and I can get kwik seal ultra from DAP for $6 and is also "Siliconized"
So far recommended alternatives are Silicone which will stick well to the membrane but nothing will stick to it, and Siliflex which is PU so is not recommend and may break down over time but has been used successfully by many members here.
Google tells me that what makes Kerdi Flex superior and pricey is it is a MS Polymer sealant (to be more exact the Kerdi Fix Spec sheet lists the base as Silyl-Modified Polymer- SMP, the Schluter websites calls it silane-modified polymer base, google tells me all the above are "MS Polymers")
This being the case I have found some possible alternatives I was hoping you all might weight in on:
LePage PL Heavy Duty Sealant $10/tube:
TDS says base is Silane Modified Polymer sounds, paintable 1 hour, cures in 24 ... sounds familiar but then says for best results not to use for immersed joints or under shower door tracks ... not building confidence
QUIKRETE® Advanced Polymer Non-Sag Sealant (No. 8660-11) ~$8/tube:
TDS says one-component, permanently flexible, multipurpose, solvent & isocyanate-free, tack free in an hour cures in 24, printable.... sounds familiar also states
QUIKRETE® Advanced Polymer Non-Sag Sealant may be used for:
Sealing & Waterproofing horizontal or vertical control joints or
expansion joints in sidewalks, driveways, industrial floors, parking
decks
Promising but I cant find anything that says what the Polymer actually is .. the elongation to break is higher then Kerdi Fix so not 100% this is the same goop
Now the Front runner
XCEL IGA $12/tube free shipping on amazon:
TDS and MDS eaisly found on the website along with a demo of them gluing 3 pavers together underwater and lifting them out...
XCEL IGA is a high strength, high viscosity, one-component elastic adhesive
for indoor and outdoor applications based on MS Polymer. Specially designed
for fast and non-rigid structural bonding in construction, metal industry, auto,
marine, etc., with excellent adhesion to most substrates. Completely weather
resistant, odourless and does not contain solvents, silicones or isocyanates.
Again sounds familiar and better yet even the elongation and density are a close match
aw material basis: MS Polymer
Consistency: Non-slump paste
Specific gravity: approx. 1.55 g/ml
Skin forming time: 5 – 10 minutes (at 23ºC; 50% R.H.)
Curing rate: 2-3 mm/24 hr
Resistance to flow (ISO 7390): approx. 0 mm
Consumption: approx. 50 ml/ linear meter (nozzle diameter: 8mm)
Application temperature: Between 5ºC to 40 ºC
Properties of the cured product: (After one week at 23ºC and 50% R.H.)
Service temperature: -40ºC to +90ºC
Shore A hardness (ISO 868): 65
Max. tensile (ISO 37): 2,50 MPa.
Modulus – elongation at 100% – (ISO 37): 1,70 Mpa. Max. tensile
Elongation at break (ISO 37): > 250 %
At $12 a tube I might just do all the membrane seams while I am at it to use up the tube!!!
Now I am a believer in things being too good to be true but at this point I am going to end up with one of the above alternatives or grab a $10 tube of silicone otherwise (Thats what a tube of MONO Silicone Pro is worth up here, don't even ask what a bottle of rum is cost)
Any thoughts?
