Unread 10-12-2013, 08:41 PM   #1
melissadurante
Month old grout rubbing off
Hey all
Grouted my glass mosaic backsplash with supertek unsanded grout last month. I went over the grout job a second time because I thought it looked too low. I think this was probably a no'no.
Anyway...the grout rubs off if I go over it with a cloth..as I had noticed s few spots with leftover haze.
Can I go over this with grout sealer to minimize this issue?
Any input is greatly appreciated.
Thanks in advance
Melissa
Melissa
melissadurante is offline   Reply With Quote
Unread 10-12-2013, 08:55 PM   #2
Deckert
I don't think a grout sealer is going to solve your problem. Skimming over existing grout with new grout doesn't work well. Generally you need to remove the old grout and re-apply new grout.
Brannigan
HeenanGC.com
Unread 10-13-2013, 01:17 PM   #3
melissadurante
Okay...thanks
Melissa
Grout is rubbing out with Grout Brush Muttonchops Cleaning, Restoration and Sealing 10 11-07-2013 01:43 PM
Grout haze removed from 3 month old backsplash cburrows84 Cleaning, Restoration and Sealing 0 08-29-2011 10:19 AM
New GROUT out last month that never molds sophiethebulldog Cleaning, Restoration and Sealing 9 08-27-2006 01:19 AM
Grout Fail a month after? Denise K. Tile Forum/Advice Board 17 09-04-2004 09:24 AM
Rubbing Compound to Remove Grout Haze. Frank Tile Forum/Advice Board 2 02-22-2004 08:48 PM
