Unread 06-22-2022, 06:44 AM   #1
mferg318
Significant Efflorescence on new tile shower floor
We just finished building a new house with a tile shower in the master bathroom. The grout for the walls and floor are both charcoal. When the floor grout was installed, it was a much lighter gray than than the charcoal grout on the walls. I confirmed that the correct charcoal color was used. Since the installation, the grout has continued to whiten, which I attribute to efflorescence. Since the grout on the walls turned out fine, I'm assuming this is not an installation issue, rather an issue with the minerals in our water. My plan for fixing is this:
-Clean grout
-stain grout with "Aqua Mix Grout Colorant"
-seal grout
-install some sort of filter to remove mineral from water and prevent future issues
Can anyone confirm whether this is an effective plan? And if so, what kind of filter can I install?
Thank you in advance for any help. It's very frustrating to have a brand new shower that looks so awful.
micah
mferg318 is offline   Reply With Quote
Unread 06-22-2022, 04:58 PM   #2
Welcome, Micah.
First, it would help to know specifically what grout was used.
Not sure both of those statements can be accurate.
Black, and other dark colors, in cementitious grouts can be troublesome under the best of circumstances. I don't see anything in your photos that would indicate an efflorescence condition, but I frequently miss things in the posted photos that the younger eyes see, so wait for more comments.
Most of my customers over the years are on individual water wells and the water in our are tends to be very hard. Whitish calcium-type build ups are common on many surfaces, and shower floors suffer mightily. Can't say if that's part of your problem or not.
If you scrape the grout on the floor with a hard tool, do you see the original grout color?
Overwatering in the mixing and/or clean-up of the grout is a common problem, again, with cementitious grouts. Painting the grout with a grout colorant is one of the more common recommendations from the grout manufacturers, but shower floors are not the best candidates for that sort of treatment, either.
Unread 06-25-2022, 09:13 AM   #3
Hi Micah,
I suggest scrubbing the floor with white vinegar and water mixed half and half. Rinse thoroughly afterward. If that doesn't work you might consider living with it. It doesn't look bad to me, and shower floor grout eventually changes color no matter how you maintain it.
Water behind tile causing efflorescence in Shower pan gregm93 Tile Forum/Advice Board 10 03-18-2022 11:13 AM
Tiling a painted concrete slab floor with efflorescence issues Regan Tile Forum/Advice Board 2 07-29-2019 07:28 PM
significant paint application on slate mmhendrie Cleaning, Restoration and Sealing 11 03-25-2013 08:35 PM
Efflorescence on marble tile floor davestew Cleaning, Restoration and Sealing 32 04-26-2009 09:45 AM
