Unread 01-07-2012, 08:56 PM   #1
Rodders
Fastening through heated tile floor
Does anyone know of a way to locate heating wires under an existing tiled floor? Many under tile heating manufacturers mention systems for finding faults; I need to locate wires in a functioning heated floor, so that a partition can be installed over it without messing it up
Rod
Rod
Rodders is offline   Reply With Quote
Unread 01-07-2012, 09:02 PM   #2
TeomanTile
If your friends with an energy auditer or a fireman, you might have access to a thermal imaging camera. This would be the best way, I'd think.
Joseph Teoman
Teoman Tile & Stone
Friends call me JT!
TeomanTile is offline   Reply With Quote
Unread 01-07-2012, 09:29 PM   #3
eurob
Not...Sure
Is there a way to attach the partition with adhesive or by other means than mechanical attachment ?
Roberto
Unread 01-07-2012, 10:11 PM   #4
HS345
Tile Contractor
HS345's Avatar
I think you may have a bigger problem. It's not a good idea to bury heating cables under a bottom plate. I would check with the manufacturer of the heating cable.
I believe most only allow you to come within a certain distance of a wall or cab, let alone under it.
The name's Greg
Unread 01-08-2012, 09:51 AM   #5
vrusso123
N. E. Ohio tile-setter
my zircon stud finder senses current. dont know if it will sense that through tile though. can always buy it at HD and if you dont like it take it back.
vincent
http://russotile.com
"just keep stickin' 'em" - Pat Reagan
vrusso123 is offline   Reply With Quote
Unread 01-08-2012, 11:26 AM   #6
TechHead
Tile nub
Thats also what I remember reading from my install instructions, nothing can be placed over the wires as it cause them to over heat.
Forrest
TechHead is offline   Reply With Quote
Unread 01-08-2012, 12:57 PM   #7
dhagin
What Greg said.
IF you put a wood sill plate & partition directly over a heated tile floor you'll likely create a hot spot and may burn out the heat, in addition to voiding any warranty.
I'd call the heat manufacturer and run your plan by them before going any farther.
dana
Unread 01-08-2012, 09:18 PM   #8
Rodders
Lots of good ideas - thanks. It may just be a crazy notion anyway, even having mapped out the wire locations, there will still be a risk of messing up. I think I know what manufacturers will say!
I need to fasten the bottom plate down at least at the door; but maybe using adhesive plus dowels that extend no further than the depth of the tile would work well enough for a light door.
I did wonder about the overheating issue - but the wires are more than an inch down under stone tiles and slu, and the slab is not insulated. Maybe steel framing would help limit the hot-spot.
Rod
heated tile floor on concrete robert66 Tile Forum/Advice Board 17 02-06-2010 07:34 AM
Heated floor/Flat tile creativetilecompany Professionals' Hangout 3 01-27-2007 02:59 PM
Recipe for a heated tile floor? PhileFriendly Tile Forum/Advice Board 5 08-30-2006 06:10 PM
fastening transition/threshold to floor question spanky67 Tile Forum/Advice Board 1 05-25-2004 09:33 AM
heated floor under tile azgunn Tile Forum/Advice Board 10 06-08-2002 09:01 AM
