Unread 08-07-2010, 09:57 PM   #16
Higher Standard Tile
Tile and Stone Contractor
Higher Standard Tile's Avatar
Originally Posted by Shawn
So, do you also let it set-up for a few minutes before grouting walls too (not 20-30, but 5 or 10)?
If you mean slaking the grout before use, I've never down that with epoxy grout. -just with cement grout.
As soon as you are done mixing start spreading. And I just mix with a margin trowel.
I must say the Spectralock is so much user friendly than older versions of epoxy grout. It definitely gives you some time to clean it up. I used to use Laticrete SP-100 and while that was still easy to use compared to old school epoxy you still had to get on it right away or have haze problems.
Isaac
Higher Standard Tile & Stone
Maui, Hawaii
spectralock full unit into mini units formula ? jim mclaughlin Professionals' Hangout 3 04-24-2009 03:27 AM
Self Contained Steam Shower/Bath Units Marge Tile Forum/Advice Board 2 04-12-2007 03:25 PM
order of operations,bathroom darcy@ waterfallceramics Tile Forum/Advice Board 12 08-10-2002 03:57 PM
