Old 02-02-2009, 02:50 PM   #1
BlownM3
Stonetech Enhancer or Enhancer Pro Sealer?
I need to seal my newly installed mosaic ceramic floor tile and grout. I also want it to be a little darker than what the grout turned out. Will I be ok using the water based Enhancer or should I use the Pro? Do I need to seal with the Enhancer or will it take care of this also? I am only going to be keeping the house for 6 months and won't be using the bathroom that much. Also would it work to apply with a small spray bottle and work it into the joints with a brush?
Sean
BlownM3 is offline   Reply With Quote
Old 02-02-2009, 04:04 PM   #2
Davestone
Florida Tile & Stone Man
The solvent based enhancers seem to work a little better but i don't know how dark you want it.Spray and brush is fine,but be sure to wipe of exces before it dries.
http://Davestonestile.com
Old 02-02-2009, 04:09 PM   #3
BlownM3
will I need to apply another sealer or will this take care of that?
Sean
Old 02-02-2009, 04:53 PM   #4
Davestone
Almost all enhancers are also sealers, always check the bottle though whatever you buy,and pay attention to the directions.
Old 02-03-2009, 11:32 AM   #5
GeorgeT
StoneTech Rep
Send a message via ICQ to GeorgeT
Hi Sean -
Both Enhancers are also sealers. The Enhancer Pro has a stronger UV resist so it is best for exteriors.
On some materials there will be slight enhancment differences between the two products... Only testing will tell you the difference in appearance.
Enhancing grout is somewhat risky as the resulting color can often be uneven and blotchy. Differing porosity and textures can cause enhancers to absorb unevenly. Again only testing will tell you how even a look you will achieve.
Whatever applicator you decide on, make sure you wipe off the tiles well so enhancer does not dry on the surface......
George T. O'Regan
Technical Services
DuPont StoneTech Professional
http://www.stonetechpro.com/
GeorgeT is offline   Reply With Quote
Old 02-04-2009, 06:37 AM   #6
doitright
doitright's Avatar
Hi Sean
You may want to consider a non enhancing impregnator (since you won't be there long), and this is a mosaic. If the existing grout just doesn't look good, the use of an enhancing sealer is a good idea, but as George mentioned, it must be TESTed, and don't be surprised if the grout becomes blotchy.
Personally, I think a good saturation of the PRO (don't spray), squeegee it around the floor, let dwell, followed by a buff dry of the tiles PRIOR to the sealer drying on the SURFACE of the TILES, will be the most effective.
John Koessler
Using slate enhancer AFTER penetrating sealer? Debutante Cleaning, Restoration and Sealing 3 07-21-2008 03:51 PM
Sealer on top of Stonetech Enhancer BlueCanyon Cleaning, Restoration and Sealing 5 11-26-2007 10:11 AM
color enhancer vs penetrating sealer vs matte sealer finisher missmarble Cleaning, Restoration and Sealing 6 09-04-2007 08:26 AM
StoneTech Enhancer Pro vs. bulletproof Brian in San Diego Cleaning, Restoration and Sealing 12 05-11-2007 08:31 PM
StoneTech Sealer (Enhancer) Alan Adcock Cleaning, Restoration and Sealing 1 10-30-2004 08:34 PM
Found usc_block_11 empty, added this: [CODE] [/CODE]
