Unread 07-06-2019, 12:41 PM   #1
JerseyDIYguy
Preparing an old fireplace for tile
Mrs. JerseyDIY desperately wants to change the look of our fireplace. She suggested painting it, but my brother owns an Arts & Crafts/Restoration/Custom tile manufacturing company, so it's a no-brainer for me to tile over it. The fireplace was built in the 1920s and is all original as far as I can tell. We use the fireplace about 10 times per year and only burn duraflame type logs. Here's the fireplace along with some close ups of the brick corbels and stair-stepping at the top:
The condition of the bricks on the outside of the fireplace is excellent with almost no cracking or separation of the mortar.
Here are some close ups of the hearth bricks and firebox:
The grout in the hearth bricks is cracked and separated in places (no cracks in the bricks fortunately). I'm not certain if it's actually grout, or just brick mortar set nearly flush with the surface of the bricks and coated/sealed somehow. The hearth grout appears to have coarser sand than typical grout, but it's also nearing 100 years old, so who knows what it could be? I suspect that most of the cracking is due to the fact that the hearth is supported by a cantilevered half-arch of bricks set into the joists in the basement ceiling below. There has been some settling of the joists over the last century and this probably caused the cracks. However, the firebox and surrounding fireplace structure is supported by a massive stone and block solid column structure that goes all the way to the floor in the basement and it has not moved and is completely intact.
I will be tiling over all of the vertical brick surfaces outside of the firebox. No tile will be added to the inside of the firebox or to the hearth - I'm leaving those alone. I have a design that takes advantage of the corbels and stair-stepping of the bricks at the top so I'm good to go for that part of the project. I'll be using mostly 4.25" and 2.75" square tiles for the field.
I have some questions and concerns with the job that I'm hoping the JB crew can chime in on:
1. There's a bit of lippage among the existing bricks that will make tiling over the surface a bit challenging. Plus I assume the existing mortar lines will need to be filled. I'm thinking of skimming/screeding the surface of the bricks before tiling to even out the surface. Suggestions on a material to use? I'd like to keep the thickness of the skimming material thin so that the overall size of the fireplace doesn't "grow" much. What should I use to clean the bricks before skimming?
2. I'm not certain what sort of "grout" is between the hearth bricks, but I'd like to repair it. I don't really want to tile over the hearth as I like the character and design of the existing bricks. Suggestions on the best approach to repair and on what sort of material to use? I'm hoping not to have to remove all of the existing grout if possible.
3. There's a bit of spalling of some of the hearth bricks in the bottom of the firebox, and some of the vertical bricks at the back of the firebox. The hearth bricks are a different composition from the vertical bricks - smoother and more uniform. What could I do to repair these? Is it really worth the effort?
4. I'd like to clean the hearth bricks. There are a number of stains which I think are wax/soot/oil of some kind. Suggestions on what to use to clean them? Chemical? Abrasive?
TIA
Warren
JerseyDIYguy is offline   Reply With Quote
Unread 07-06-2019, 02:43 PM   #2
1. I'd put a 1/2 inch mud bed over the face bricks except for the top row. That way the surface would be very flat. But, sounds like you want to just fill in the mortar joints and lippage. There are several products that will work similar to this. https://www.custombuildingproducts.com/TDS/TDS-111.pdf
A wire brush might clean the bricks well enough. I would try that first.
2.You might look into cleaning the bricks and filling the cracks. You will likely need to cut the cracks a little deeper for new grout to bond. A grout stain would work and possibly even help the looks of the bricks. I would experiment with that.
3. Removing bricks may turn into more of a job than you want. But, that's up to you.
4. I would start with household cleaners and go stronger if you need to.
Unread 07-07-2019, 01:14 PM   #3
JerseyDIYguy
Thanks for the tips Davy.
For the skimming/screeding material I definitely want to keep it as thin as possible. Any recommendation for something that will set up a bit slower than Custom's Skim Coat? Their instructions say "Mix amounts that can be applied in 10 minutes" which isn't long for someone who likes to work slowly.
For cleaning the hearth bricks we've already tried most common household cleaners. We've also tried heating and blotting the stains, which worked to some extent, but still left the bricks stained. Any suggestions for something stronger? Muriatic Acid maybe?
Warren
Unread 07-07-2019, 01:25 PM   #4
You can use modified thinset to fill those low areas even though it's not designed for doing this. It is slow setting.
Muratic acid isn't recommended even though it might help. The fumes are dangerous and can harm metal surfaces inside your house. It's possible the acid may harm the bricks too, depending how strong you mix it. If you plan to use it, I'd mix it about 15 parts of water to 1 acid and rinse well with water.
I'd try vinegar first.
Unread 07-07-2019, 08:29 PM   #5
On those bricks that protrud you could put some relief cuts deep enough to make it flush with the rest of the bricks and then knock the pieces off with a chisel. Then skim everything with thinset.
Unread 02-29-2020, 11:04 AM   #6
JerseyDIYguy
A new problem
I removed the wooden mantle from the top of the fireplace the other day and (surprise!) there's an additional 2-3/4" high course of bricks that was hidden inside the mantle on top of the exposed bricks. The problem is that the faces of these (formerly) hidden top bricks are flush with the faces of the course of bricks directly below (those are the bricks you can see in the third photo in post #1). The newly exposed bricks don't continue the "stairstep" pattern that projects outward.
There's no way I can remove the top course of bricks (they're partly embedded into the wall), so the wife would like to continue the stairstep pattern and add an additional course of tile to the faces of the top bricks. That leaves me with the problem of how to add an additional ~1/2" of horizontal depth to the faces of all of these top bricks. In total there's about 8 linear feet of bricks in that top course.
My initial thought would be to cut 2-3/4" strips of 1/2" thick Hardiebacker. Then I'd adhere the strips to the face of the bricks with mortar and let it set. That would create the additional stairstep at the top course and then I'd just tile directly to the Hardiebacker.
Any issues with adhering a strip of hardiebacker to a brick face?
Warren
Unread 02-29-2020, 11:32 AM   #7
To answer your question, no. Thinset will bond the Hardiboard or cement board to the brick. The problem usually is with the bricks you're sticking to. If they are crooked and not flat then your Hardi will follow it. The Hardiboard must also be cut straight.
Unread 02-29-2020, 05:04 PM   #8
JerseyDIYguy
The good news is that the newly exposed bricks are very straight. So if I used long strips of Hardibacker (2-3/4" x 5') and I could get it to sit flat and straight against the bricks would that work?
Warren
Unread 02-29-2020, 07:37 PM   #9
I don't know, might work fine, that's your call. Hardi isn't designed to be used that way and I've never tried it. I would mud it myself (see post 2).
Unread 03-02-2021, 08:48 PM   #10
JerseyDIYguy
Grout discoloring tile
All of the tile is up on the fireplace. I'm pretty happy with the way it turned out - there's a bit of lippage here and there, but nothing too awful.
Now it's time to grout and I have a dilemma...
I bought Ardex FH grout in their Baked Terra Cotta color which goes perfect with the tile. I made up a grout test board.
In the attached picture the test board has 5 columns as defined by the 5 columns of small tiles across the middle. I put several pieces of painters tape vertically across the larger tiles at the bottom of the test board in line with the columns. Before grouting I treated the left most column with 2 coats of Mapei Tile and Grout sealer. The second column has 1 coat of the Mapei. The center column is unprotected. The 4th column has 1 coat of Aqua Mix Grout Release, and the last column has 2 coats of the Aqua mix. The two coats of Aqua Mix definitely did the best job of keeping the grout from getting into pores and bubbles on the surface of the glazing, plus it did the best at keeping the overall surface somewhat clean.
My problem is that when I peeled off the tape pieces it was obvious that even after repeatedly cleaning during grouting the grout was discoloring the faces of the tiles. The discoloration was least noticeable where I put 2 coats of the Aqua Mix, but it’s still a problem.
Then I tried Aqua Mix heavy duty tile and grout cleaner which is recommended by Aqua mix for removing grout haze/discoloration. It worked a bit, but not completely. It also left a lot of white streaking in the actual grout joints (see photo), so I don't think that is a good approach. I also tried a scrubbing sponge (blue plastic Scotch Brite) with water and that helped a bit, but not much.
I’m thinking of trying a tile with 3 coats of the Aqua mix.
Any suggestions for getting rid of or preventing grout haze? Hopefully something that won't cause streaking in the grout joints. I've read about using tape or shelf paper type materials to completely cover the faces of the tiles and cutting out the grout lines, but I'm hoping there's a less labor intensive option.
Warren
Unread 03-02-2021, 11:13 PM   #11
Are you happy with the grout? Maybe it's just the picture but it sure looks splotchy to me.
I've never used Ardex but did you try buffing off the haze with a clean rag about an hour after washing the tiles? I wouldn't be happy with the way the grout stains the tiles. I would get that problem taken care of before grouting.
Unread 03-02-2021, 11:48 PM   #12
JerseyDIYguy
Pretty much all of the splotchiness was caused by the AquaMix heavy duty cleaner I used. It caused a white, powdery residue to appear in the joints. Prior to that the grout that was actually in the grout joints looked very good. On top of that, the lighting in the picture tends to make the joints look worse than they actually are.
I definitely want to do something to prevent the discoloration of the tiles, I just don't know what the right answer is.
Warren
Unread 03-03-2021, 08:54 AM   #13
The tiles look to be glazed. It's hard to tell how much texture the tiles have. Did you try to buff off the haze with a rag 45-60 minutes after washing? I don't know if this is a characteristic of Ardex grout. Maybe someone else knows.
Unread 03-03-2021, 09:39 AM   #14
JerseyDIYguy
Yes, the tiles are glazed. However, they were fired in a very high temperature, reduced oxygen gas kiln. This was a deliberate choice in order to give them the color variation that you see in the pictures. It resulted in the surface of the tiles having more texture and variation than most, and that seems to be a part of the reason for the discoloration with the grout.
I did buff the tiles as soon as the grout was dry. The Ardex grout seems to have a very fine pigment powder in it that apparently loves to get into the glaze on the tile. Short of masking off the faces of all of the individual tiles I'm not sure how to proceed.
Warren
Unread 03-03-2021, 04:44 PM   #15
I'd switch to Prism grout. But that's just me.
https://www.custombuildingproducts.com/TDS/TDS-128.pdf
Preparing a fireplace for tile IMSA Tile Forum/Advice Board 10 10-17-2011 03:07 PM
Preparing floor for tile kurtwm Tile Forum/Advice Board 1 07-21-2009 08:17 PM
Preparing floor for tile mightyatom Tile Forum/Advice Board 3 04-08-2006 12:47 PM
Preparing a curb for tile Keith.Brown Tile Forum/Advice Board 2 10-25-2004 07:19 PM
Preparing walls for tile. lane21 Tile Forum/Advice Board 0 03-11-2004 11:39 AM
