Unread 05-16-2016, 01:48 PM   #1
Bowie
Wrong grout in Pebble shower floor
So we have flat pebbles in our shower/ tub combo. Looks great. Until we went to grout the pebbles. We went with Custom Building Products - Fusion Pro®. I am sure it works well when installed in 1/8" and less grout spaces. But it has cracked everywhere on this install. I am wondering what is the best solution moving forward. I installed a Wedi product underneath the pebbles along with RedGuard. So I feel like it is waterproof but I really don't want the grout to have cracks in it. Plus I feel like it will only get worse as time goes on. I now have done my research and it looks like you should only install sanded grout in with pebbles.
But I need some help here for moving forward. I don't want to compound the error with another one. So can someone please help.
Please add to below if you see more options or solutions
Options:
1. Remove the Pebbles and start over
2. Remove as much grout as possible and then regrout with sanded grout
3. Remove the grout where I see cracks and put the same stuff back down.
Kyle
Bowie is offline   Reply With Quote
Unread 05-16-2016, 06:09 PM   #2
koihito
A person, like you.
koihito's Avatar
Welcome Kyle,
If would strongly suggest option #1. Fusion Pro is not a bad grout in the right application, but a pebble floor, especially one in a shower, is not one of them.
Nate
www.mikoskiconstruction.com
Unread 05-16-2016, 08:41 PM   #3
Hi Kyle,
I'm sorry to say that I agree with the more painful option #1.
How long has it been since installing pebbles and grouting with Fusion Pro?
Unread 05-16-2016, 08:54 PM   #4
evan1968
Not So Senior Contributor
evan1968's Avatar
Fusion Pro's literature states it's not for use on pebble floors or with grout joints larger or deeper than 1/2".
Craig
Commercial Tile Installations
KEEP CALM and TILE ON
Unread 05-17-2016, 09:58 AM   #5
Bowie
Well I have not even had a shower in their yet! I did hear back from the grout manufacturer. They suggested using an epoxy remover to remove the grout. I tried it last night and it actually comes out very easy. I think I may go this route and then apply a cement based grout over the top. That is what the manufacturer is suggesting.
Kyle
Unread 05-17-2016, 10:32 AM   #6
Bowie
Totally agree!! But it does not say that on the bucket. How many contractors actually read the website? Probably not many. Plus almost all the grout says not above 1/2 inch. So by specs the Prism is not supposed to be installed either along with all but one of their sand grout. Just frustrating. The manufacturer said to add sand to one of the cement grouts to ensure it does not crack. We will see how it goes getting all the grout out.
Any other thoughts??? Thanks a ton.
Kyle
Unread 05-20-2016, 11:12 AM   #7
Bowie
Shameless bump
Kyle
Unread 05-22-2016, 02:36 AM   #8
Kymberly in AK
Hi Kyle,
I used that same grout in a flat pebble shower and had no cracking issues. Was it hot or dry or both at the time you used it? I had issues getting it off the stone and ended up digging out the joints a bit more than I'd like. But this stuff is now like cement and not a single crack.
Kym
Kymberly in AK is offline   Reply With Quote
Unread 05-22-2016, 01:18 PM   #9
dhagin
Around here, most. Out in the rest of the world is anyone's guess. Judging from the amount of problem jobs from "contractors" we see here, I'd have to say 'very few'.
dana
Unread 05-22-2016, 02:54 PM   #10
Tiger Mountain Tile Inc
In addition to the specs for Fusion is the specs for a Wedi shower pan. The manual states that tile under 2x2 inches needs epoxy grout. They do have an exception for pebble shower floors but the exception if to use modified cement grout. (page 8)
James Upton
Why you should NOT buy a newly remodeled home ~DIYTileGuy
Unread 08-10-2016, 08:33 AM   #11
mikec557
End result?
Hi Bowie
How did your fix turn out in the end? I have a similar floor in my upcoming project, and I'll post my questions there; but, I would like to know what grout you ended up using and was it sanded or unsanded?
Signed
Inquiring minds want to know
(Mike)
mikec557 is offline   Reply With Quote
Unread 08-10-2016, 10:00 AM   #12
MAPEI - Technical Service
Company Representative
This is the product we recommend for pebbles. It's a high-end cement based grout that is designed to not crack or discolor:
http://www.mapei.com/public/US/produ...rplusfa-en.pdf
Holden
http://www.mapei.com/US-EN/
Unread 08-10-2016, 10:54 AM   #13
mikec557
Thanks, M.T.S.
Wrong grout for flat pebble shower floor? brgirl Tile Forum/Advice Board 17 06-06-2014 10:31 PM
Pebble Floor Grout Problem? rkymtn Tile Forum/Advice Board 9 04-18-2013 11:11 PM
Using Pebble for Shower floor Mar Tile Forum/Advice Board 7 12-21-2011 11:06 PM
Pebble floor in shower Bella Vista Tile Forum/Advice Board 3 05-28-2008 06:13 PM
What to "Do" with a pebble stone floor gone wrong? Beko Tile Forum/Advice Board 15 12-21-2006 12:41 PM
