Unread 02-01-2016, 09:39 PM   #1
Slowtile
Pebble help (grout issue)
Not finding a lot of info on this, heres my issue. When researching I found mixed reviews on sealing pebbles before grouting.. Either way after grouting my white/gray pebbles they turned brown. I need to get these cleaned up ive read sanding is possible but also read about maybe an acid cleaner? Any help would be greatly appreciated, thanks guys.
Matt
Slowtile is offline   Reply With Quote
Unread 02-01-2016, 09:58 PM   #2
Matt,
1- Got pics?
2-What grout did you use?
3- What kind of rocks are they? Can you get information from the manufacturer? *
*the ones who came after God made the rocks.
Unread 02-01-2016, 10:39 PM   #3
Slowtile
Tec accucolor from menards sanded light grey.
This is the stone
http://m.lowes.com/pd/American-Olean...-5-in/50122049
Matt
Unread 02-01-2016, 11:28 PM   #4
Slowtile
What about this?
http://www.mapei.com/us-en/product-d...29&IDLinea=143
Anything better?
Matt
Unread 02-02-2016, 07:25 AM   #5
Matt,
Call Tech support at Mapei. They will best guide you. Mighty fine folks there.
For additional information and to access product data sheets, warranties and technical services, please contact MAPEI Technical Services at 1-800-992-6273 (USA and Puerto Rico) or 1-800-361-9309 (Canada), or visit www.mapei.com.
Unread 02-02-2016, 09:54 AM   #6
shenandoahman
Matt, your experience is the reason why I also use a pregrout sealer whenever I'm installing a natural stone or unglazed product. The surface is porous and makes it difficult to remove the grout residue which I think is what you're seeing. Call the tile manufacturer before you use a haze remover. It could cause a whole new set of problems.
Gary
Gary
shenandoahman is offline   Reply With Quote
Unread 02-02-2016, 12:36 PM   #7
dhagin
Not 100% sure, but it appears that product is not approved for wet areas or shower floors.
As it is a light colored stone, and may be very porous, a few things may me happening here or any of them combined with others. Without photos showing the wet "brown" stone as you describe, I'm only speculating based on other similar looking stone used in shower floors.
1- it may just be moisture. And it may take a long time to dry out after each shower such that it always remains wet.
2- the moisture may have caused minerals within the stone to rust, which you see as a brown color
2- the grout may have stained the stone
Can you get it wet & "brown" for us and take a few more photos?
dana
Unread 02-02-2016, 10:14 PM   #8
Slowtile
We have not used the shower yet. Once grouted we cleaned as best we could and the haze left just hasnt come up completely. I have pieces I havent used , wetting them doesnt create a brown color. Im guessing the grout has hazed the stone? I called mapei and they recommended the acid cleaner.
Matt
Unread 02-02-2016, 10:45 PM   #9
dhagin
I can't see it from here, post some photos for us.
dana
Pebble stone discolored after grout kimmyw75 Cleaning, Restoration and Sealing 3 02-03-2016 01:05 PM
Pebble Floor Issue mrbreakit Tile Forum/Advice Board 19 08-10-2013 07:26 AM
Pebble Tile Grout Thegov3 Tile Forum/Advice Board 5 10-01-2005 12:35 AM
how do you grout pebble/stone mosaic?? mommybgood Tile Forum/Advice Board 4 08-21-2005 07:04 PM
Can I Remove Some Grout From Pebble Tile? nantasket Tile Forum/Advice Board 7 02-29-2004 01:59 PM
