Unread 05-22-2012, 02:21 PM   #1
Dazed & Confused
Deflecto calculations
I am looking to install a ceramic tile floor in my kitchen. I am down to the 4.5 x 3/4 floor planks. The deflecto calculator on your website suggest that ceramic flooring will not be acceptable for my floor and joist.
I have received estimates from several installers. Not one mentioned the deflecto calculations. Most of my basement is finished living area. The utility room, where most of the kitchen floor is located, is exposed. They examined the joist and planked flooring no one ever suggested that I could not tile the floor above. Are there other factors that the calculator does not take under consideration?
The joist are 7.25 x 1.5. The distance between the joists is variable. The outside joist measure 14.75 inches the rest are 13 to 13.75 inches. Length appears to be 14 - 16 feet. Could be longer I don't know. I can measure 14 feet. The rest is located in the finished section and below ground level to outside wall. There is a steel beam located at 13.5ft from outside wall. Also there is diagonal bridging running the width of the kitchen floor. The floor seems to be in good shape. I have not idea of what type of wood this is.
There is some squeaking. Adding screws to joist stopped the squeaking in the two board that I tried. Should I do this to the rest of the floor before having the 1/2 plywood installed?
I have uploaded pictures hopefully this helps.Name:  topview.jpg
Any suggestions as to how I should proceed at this point
Dee
Last edited by Dazed & Confused; 05-22-2012 at 02:38 PM. Reason: Forgot to mention the distance between joist
Dazed & Confused is offline   Reply With Quote
Unread 05-22-2012, 05:11 PM   #2
Dazed & Confused
Question Deflecto Calculations
Hi Bob,
Correction: My tiles are 6 x 6 porcelain and not ceramic. There does appear to sister boards running together towards the end of the joist in the utility room. The measurable overlap is approximately 1 foot. The rest is located in the finished area. I can't tell.
My floor is definitely solid. With minimal squeaking in high traffic areas.
Resting on top of the steel support column I mention is three 1-1/2 thick beams running horizontal which apparently runs the length of the house.
Will any of this make a difference in deflecto calculations?
Dee
Unread 05-22-2012, 05:53 PM   #3
Welcome, Dee.
Porcelain tiles are ceramic tiles. More dense and generally harder ones.
'Fraid I'm not understanding at all what you're telling us there. A drawing or a photo of that area, perhaps?
Again, a drawing or marked up photo would help. I really can't see what you're describing from over here even if I stand on Paul's chair.
May very well if we can figger out for sure what "any of this" is.
You want no squeaks in any area. Squeaks indicate movement. Ceramic tiles do not like movement. At all. None.
Get some decking screws in those subflooring boards to stabilize them. I strongly recommend pre-drilling the boards, too. A really big PITA? Yep. A bigger PITA than a tile installation failure? Nope.
Unread 05-22-2012, 07:24 PM   #4
Nope, even with the winder open I can't see nuttin.
Try laying on the (basement) floor and taking a picture of the joists in question.
Circle Design Calculations K_Tile Professionals' Hangout 3 09-29-2008 03:51 AM
Help With Subfloor Thickness and Joist Calculations for Slate tdi66 Tile Forum/Advice Board 3 02-06-2007 06:54 PM
Deflecto Help JPicasso Tile Forum/Advice Board 1 03-09-2005 07:03 PM
Deflection rate calculations John Joesph Tile Forum/Advice Board 2 12-01-2002 10:45 PM
