Unread 02-23-2009, 08:38 PM   #1
HS345
Tile Contractor
HS345's Avatar
Another Hack Job
Working on a repair, I'll let the pictures speak for themselves.
The name's Greg
Unread 02-23-2009, 08:41 PM   #2
java
Hugging Trees Oct. 1st
java's Avatar
Did you say repair or redo?
Looks like it would be a complete tear out.
Jason
java is offline   Reply With Quote
Unread 02-23-2009, 08:48 PM   #3
HS345
Tile Contractor
HS345's Avatar
And a few more.
The name's Greg
Unread 02-23-2009, 08:51 PM   #4
olzo55
Guest
Posts: n/a
Don't tell me you've never screwed a liner down? How else can you keep it from moving when the water swells the floor?
olzo
Unread 02-23-2009, 08:54 PM   #5
HS345
Tile Contractor
HS345's Avatar
Replacing the base, a foot or so of glass up the walls, and the marble on the outside of the shower.
Informed the HO that the seat would become saturated and mold, and crack and split.
I know I'll catch some flack from you guys, that's okay, I've dished it out for the same thing. I just thought you all might "enjoy" the pics.
HO signed a release.
What can I say, I need the work. T & M.
The name's Greg
Unread 02-23-2009, 08:57 PM   #6
Shaughnn
Trowel Monkey
Shaughnn's Avatar
What a damn waste of materials. Did this guy use the lath just where the liner wrapped up the walls, or did he plaster the whole thing? Does your state provide any recourse for the client to go after this fraud?
Shaughnn
Unread 02-23-2009, 08:59 PM   #7
HS345
Tile Contractor
HS345's Avatar
Not only was the liner screwed up....er....down, but it was run up the walls at least a good 1/4"..........on the outside of the cbu.
Best I can tell, those screws left sticking up were used as a mud gauge.
I guess the slope was so bad, the HO tried to make the "tile guys" fix it by mudding over the 1x1 glass already installed on the floor. The "mud" looked like pure portland, and it appeared to have been poured in multiple layers.
No lath, thank God.
I'm not sure, but I can't imagine a judge exists that wouldn't award the guy something.
HO claims he didn't pay the bums, and kept their wet saw. A Ridgid.
The name's Greg
Unread 02-23-2009, 09:12 PM   #8
gueuzeman
Ouch! But it doesn't look like it had been grouted, did these "tile guys" (more than one?) get thrown off the job before completion? Too bad, they never got the pleasure of watching their living room ceiling collapse. And where did the HO find these clowns? Recommended by a store that sold them all that pricey glass?
Hooray for you to get a t&M repair. Too bad you didn't get it from the start.
gueuze
gueuzeman is offline   Reply With Quote
Unread 02-23-2009, 09:17 PM   #9
HS345
Tile Contractor
HS345's Avatar
Not sure where he found the "tile guys".
Yes, they got thrown off the job.
One wall had been grouted, badly. I know, hard to believe.
I almost forgot....... the Pièce de résistance:
The name's Greg
Unread 02-23-2009, 09:20 PM   #10
i like the drain location.
People can spend on the materials but they wont on the install until its a hack job and has to be redone and costs more then the higher bid from the beginning.
when you fix it will you screw the new pan liner into the old one?
Unread 02-23-2009, 09:27 PM   #11
HS345
Tile Contractor
HS345's Avatar
Naaaa, I got a gallon of X 15.
The name's Greg
Unread 02-23-2009, 09:27 PM   #12
gueuzeman
Drain- ok, I'll ask. After they chopped out the plywood that is suposed to be supporting the floor.......they what? Put down poly and poured SLC? Looks pretty smooth on the bottom, any wile in there, maybe?
gueuze
Unread 02-23-2009, 09:30 PM   #13
HS345
Tile Contractor
HS345's Avatar
Naaa, they went all out, double layer of 1/2" Wonderboard.
How do you like the upside down trap, and pvc/abs connection?
The name's Greg
Unread 02-23-2009, 09:39 PM   #14
duneslider
Utah Tile Contractor
I have never seen threaded traps, other than those used for sinks. I ain't no plumber though.
Since they obviously installed that drain, why did they choose to put it next to the wall like that?
Bryan
EX Tile Contractor
Positive Tile and Stone
Salt Lake City, Utah
duneslider is offline   Reply With Quote
Unread 02-23-2009, 09:39 PM   #15
double layer of wonderboard? that's like a deflection of L/1080? right!!??
Would that shower even drain with the trap that high? i don't know too much about drains and such only water lines. Abs is extinct where i live.
aesthetics duh!!
good, hopefully you just took a hack off the market.
Hack jobs of all hack jobs pitterpat Professionals' Hangout 76 09-14-2008 04:41 PM
Any advice you guys can offer on not getting a HACK ! chefwong Professionals' Hangout 16 05-24-2007 01:24 PM
What a hack job. muley Professionals' Hangout 13 03-07-2007 01:06 PM
Hack job Northwest Tile Guy Professionals' Hangout 19 12-09-2006 06:57 PM
