Unread 09-16-2019, 02:01 PM   #1
jspernc1
drain not level
Putting in a kbrs system with oatey 3 piece drain. I thought I had the drain level before I set the tile basin but somehow it shifted about 1/8 to 3/16 out of level. I am not a tile guy by trade so I don't know if that is significant enough to be a problem. I thought about how to level it. I sanded off the threads of the screw in piece enough to just about get it level. There is a bit of play now. Can someone with tile experience tell me why I should not lock it in with mud, at the proper height and continue on with my floor
joe
jspernc1 is offline   Reply With Quote
Unread 09-16-2019, 02:09 PM   #2
speed51133
I am not familiar with sanding off threads of a drain to make it level.
Can you describe this better?
Unread 09-16-2019, 02:14 PM   #3
jspernc1
drain
I simply sanded off the threads to give the screw in piece some play side to side. now its pretty much level and while the threads are not fully supporting the drain piece Iam asking is there a technical reason I am missing as to why I can't lock it in with the mud that is going around the drain housing which is set into the tile basin?The screw in tail piece is still still full length into the housing
joe
Unread 09-16-2019, 02:15 PM   #4
jspernc1
the mud will be securing the drain screw in piece instead of the threads.
joe
Unread 09-16-2019, 02:23 PM   #5
Welcome to the forum, Joe.
Is it okay? Well, it's yours to do with as you please. Nobody will come put you in "tile jail" for it. But I doubt you'll find anyone reputable that'll say that's an acceptable method.
Will it work? I don't know. It might. Might not. The fact is it just probably hasn't been done before, so who really knows?
If it were me, I'd get an inside pipe cutter, remove the existing drain, and spend another $10 to start over. Then I'd not have to worry whether or not it would work.
Unread 09-16-2019, 02:29 PM   #6
jspernc1
so the 1/8 out of level is too much if I just screw it in with a new drain. The only worry I had about that was if there would be a small bit of standing water right at the drain. Kbrs has plenty of slope to get the tile to the drain.
joe
Unread 09-16-2019, 03:25 PM   #7
Carbidetooth
Hmmmmm
Carbidetooth's Avatar
Your concern is valid. If it would impede flow at drain, I wouldn't consider leaving it as is. Ad hoc solutions are sometimes necessary, but if you decide to proceed it will be harder to unwind later and I doubt you want to look back with the coulda-woulda-shouldas.
There is no level "tolerance" that would answer your question. It's level or it's not.
Peter
Unread 09-16-2019, 06:20 PM   #8
jspernc1
I guess I'll have to pick my evil. redoing the drain is not an option. The kbrs basin is in. no way to change it now. Oatey has a drain that that will drain across the full 4 inches. I guess that's what I'm going with. I really don't see why my improvised idea would not work. but I'll live with the 1/8 inch out of level now that I have found the drain cover I'm describing. I don't think any water will stand at the side of the drain.
joe
Unread 09-16-2019, 07:37 PM   #9
jspernc1
1/8 inch never seemed so big
joe
Unread 09-16-2019, 08:16 PM   #10
smifwal
Close enough is never really close enough...
Unread 09-17-2019, 01:48 AM   #11
Not that it matters now, but I can't help wondering how it shifted so much to make the drain that far out if level, but the basin still fits.
Did the riser shift, or was the drain glued on crooked?
Unread 09-17-2019, 08:59 AM   #12
jspernc1
I really don't know how it shifted or when it shifted. I'm at a point I need to make it work. I don't know why it wouldn't fit if the drain moved 1/8 inch. I had plenty of seal around the drain clamp to apply the shower seal. Can you explain?
joe
Unread 09-17-2019, 11:10 AM   #13
Mdsims
Thoughts on why your drain might be crooked
Disclaimer, I might be an engineer, so this might be read better with a healthy dose of beer.
.................. l
_________ . l
................ U
If that image is the horizontal drain line, p trap and riser: it's pretty common that if the riser isn't perfectly centered with where the pan drain wants to be, pushing the riser left or right to 'fit' will induce a pretty severe 'out of plumb' angle on the riser. The pipe itself doesn't mind moving a little each way, force-wise it's very easy to do with just a finger, but put a level on the riser and you'll see plumb starts wandering fast the more you push the riser. It's leverage.
My guess would be something similar happened to you here. Everything was plumb and flat, riser was pushed over slightly when the pan went down, glued, then the next day the 1/8" tilt was noticed.
The work-around I've used when the pan connection has to be perfect is to
1. be as perfect as possible on laying out the riser, seriously the best plan.
2. leave the connection from the ptrap to the horizontal drain loose (the period in the above picture) until I've dry-fit the pan/drain/riser a few times and know how everything is reacting. You can account for the plumb problem by clocking that trap fitting slightly in the opposite direction of the way you shift the riser.
All this sounds messy, but if the riser needs to shift 3/4" to the right, angle the riser ever so slightly to the left when you glue the trap to the drain line. That little slack helps everything line up.
If you're on a crawl space, and need to get that tilt out, cut the horizontal drain and insert a coupling then reglue, that will relieve some of the twist/strain in the long lever arm. Cut at the 'x' in this image.
................... l
____x_____ . l
.................. U
Matt
Mdsims is offline   Reply With Quote
Unread 09-22-2019, 08:01 AM   #14
jspernc1
kbrs shower basin
I have installed a shower basin and I have Screwed it up big time. I have never built a shower but everything was good up until I laid the tile in the basin. Unfortunately I did my walls first and thought I would do the floor last . Big mistake on my part. I had some poor adhesion of tiles and I did one of the dumbest things I have ever done and pull the tiles from the pan. Naturally The waterproofing is now messed up. Can someone PLEASE give me some advice on what approach I should take on saving this install. I have places where thinset is stuck to the basin and places where the thinset came up as well as the membrane. I'm really down about the mess I have created. I know about redgard. should I fill in the spots where the thinset came up with new thinset and waterproof. with redgard. also I have some shower seal sealant from kbrs / polyeurethane. Will thinset/ red gard stick to it. Thanks for any advice I may receive I am despreate at this point. I have a nice looking shower installed with a floor I screwed up at the last second.
joe
Unread 09-22-2019, 08:23 AM   #15
Hi, Joe.
Everything is fixable. But we need more info. Could you post a picture or two of what you’ve got there?
KBRS Shower Wedge Questions perna00 Tile Forum/Advice Board 0 03-20-2019 04:39 PM
KBRS shower base issues Brad2001 Tile Forum/Advice Board 1 12-17-2012 06:20 PM
KBRS Tileable Shower Base tweedlet Tile Forum/Advice Board 15 09-30-2012 02:51 PM
KBRS Shower Slope/Pan Over Old Pan nsoldon Tile Forum/Advice Board 8 02-07-2011 10:32 AM
Question about KBRS shower Pans jdowdy Tile Forum/Advice Board 0 05-21-2010 10:25 AM
