Unread 09-12-2019, 12:10 PM   #1
cataan
Using Kerdi on concrete slab rather than Ditra
Hi everyone -- was hoping to get some advice from you Kerdi vets and pros.
I am removing some tiles and slate from a floor due to cat urine residue. Enzymatic cleaners have cleaned all they can, the smell remains and some has gotten down into not only the thinset, but also the concrete slab (I've removed the thinset).
Since I'd only be removing a portion of the tiles/slate, I can't use Ditra because that would create a floor height differential. Kerdi, however, adds negligible height, so I thought I would use it to prevent the smell from transmitting up into/through the new tiles and grout lines. And if it doesn't work as well as I'm hoping, other than cost I don't see a downside.
I don't know what I don't know so would appreciate your thoughts!
Clayton
cataan is offline   Reply With Quote
Unread 09-12-2019, 07:39 PM   #2
Kerdi isn’t rated for that.
But maybe consider Nobleseal CIS. It’s only 1/16” thick, is rated for such use, and has a spectacular perm rating.
Unread 09-13-2019, 08:52 AM   #3
cataan
Thanks Tool Guy
When you say not rated, is that in reference to the perm rating - I know Kerdi DS has a much lower perm rating (steam showers) but is really expensive. Will take a look at the Noble product - thanks!
Clayton
Unread 09-13-2019, 10:52 AM   #4
I mean that Kerdi isn’t designed or rated to be installed over a concrete slab on the floor.
Ditra on concrete slab seanmmcc Tile Forum/Advice Board 1 07-14-2013 08:45 AM
Ditra on Concrete Slab on Grade in Kitchen Richkid Tile Forum/Advice Board 5 03-09-2012 10:41 AM
Should I scarify 33yo exterior concrete slab before Ditra? eonibm Tile Forum/Advice Board 3 09-10-2011 02:22 PM
Ditra Question on Presloped concrete slab pperry Tile Forum/Advice Board 9 10-31-2009 12:13 PM
Ditra on concrete slab MARK3980 Tile Forum/Advice Board 24 11-19-2008 02:01 AM
