Unread 03-07-2012, 06:49 PM   #1
tc128
building out the tub apron by furring it out and then tiling it?
You know that apron on a typical standard tub that goes down to the floor? It's part of the tub that I would like to have furred out with wood framing and then tiled over. I'd furr it out no more 3.5 inches using 2 x 3's. Has anyone tried this and had success in changing the look of the tub? Any pictures I can get links to?
Tony,
More than a weekend warrior, but less than a full time terror
tc128 is offline   Reply With Quote
Unread 03-07-2012, 09:31 PM   #2
dhagin
I've never done anything like that, but if you can get the short wall sufficiently anchored against movement I see no reason why it wouldn't work. Sealing the joint between the tub and this new wall against water intrusion will be critical to havin it last.
I'd prolly want to waterproof it, then seal the waterproofing & backer & tile at the tub.
You can try a google image search starting with this in the search box. Change the "tubs" to other stuff too...
site:johnbridge.com tubs
dana
Unread 03-08-2012, 11:01 AM   #3
There are some pictures on here somewhere. Try Google and also our advanced search option.
Tub apron tiling? lbailey_1234 Tile Forum/Advice Board 4 03-27-2010 07:36 PM
tiled tub apron Dimmi Tile Forum/Advice Board 7 07-09-2006 04:45 PM
Tiling a tub apron splatgirl Tile Forum/Advice Board 6 07-20-2005 06:43 AM
tiling bath floor...tub apron? sns Tile Forum/Advice Board 1 03-12-2004 07:30 PM
Tile at tub apron mgi Tile Forum/Advice Board 11 02-27-2004 09:23 AM
