Unread 01-26-2011, 11:56 AM   #1
Leah F.
Leah
CPE bunching at drain
Hi,
I am Leah and someone is installing their first shower pan for me in my shower. Here is a photo of the CPE at the sub drain. My installer laid a 1/4 sloped morter bed beneath atop of a 3/4 in. plywood on top of our wood subfloor. He is referring to the Michael Byrne book "Setting Tile". My concern is where the CPE is bunching around the circumference of the drain.
Also, do the holes in the flange of the drain look like they will allow water to seep out?
Does my installer needs to redo something here? If so, how would he proceed? Would he need to cut away the bunched material and reapply the CPE flat over the drain?
I am grateful for any advice from your friendly forum.
Leah
Leah F. is offline   Reply With Quote
Unread 01-26-2011, 12:01 PM   #2
Looks like he cut the liner too tight around the fitting and stretched it. Take the top part off and cut away the liner a little at a time around the fitting until the material relaxes.
It does look like the liner covers the weep holes. I'm not sure they won't work that way, but it is easy to fix.
Unread 01-26-2011, 08:11 PM   #3
I don't know what the blue stuff is but it looks like he may have put it under there to form a gasket for a good seal. Then, when the bolts were tightened, it forced it out under the liner. If that's what it is, he put way too much. I would take it all apart and clean it up.
Unread 01-29-2011, 03:35 PM   #4
Leah F.
Leah
Dear Bob and Davy,
Thank you so much for your replies, I was so relieved that it wasn't a difficult problem to fix. When I told my installer that I had put the question up to your forum, he was very worried that the answer would be to tear it all out and start over again.
The installer said that the CPE did not bunch up until he put the top flange on, so I asked him to do as Bob suggested to take the top part off and press the CPE material flat. Installer had no problem getting it flat before reinstalling the top flange. While he was at it, he cut away the CPE where it was bunching up into the weep holes.
Also, he had made the reinforcement layer too small a diameter and that was mucking up the works because it was curling up on the edge of the flange, so I asked him to remove it and not to bother putting on a new one. Yes, I'd say he was using way too much blue stuff (Noble sealant) so after he removed the reinforcement layer, he cleaned all the blue stuff off the CPE before he put the top flange back on.
The water test succeeded and the project has moved on--whew!
Have a great weekend. Thanks for being there for us newbies.
Leah
Unread 01-31-2011, 05:31 AM   #5
Thanks for the feedback, Leah!
Unread 02-11-2011, 10:50 AM   #6
Leah F.
Leah
How long and how much to tile a small shower?
Hello there,
I have a 3 ft. x 3 ft. shower with three walls and a 6" tall dam. There is a valve, an ell, and a fixed shower head. The shower is on the ground floor and the tile are basic Daltile 4" x 4" ceramic tiles. There'll be a 6" tall mosaic ribbon and the same mosaic on the shower floor. The mosaic is made of porcelin 1" tiles.
My inexperienced installer has been thinsetting the tile for 4 full days now, yet is less than one-quarter done. Because there were so many unknowns up to the tiling, I have been paying him a daily rate, but now he is at a point where I do not think it is fair to me to pay him on an hourly basis, especially since I suspect that he is taking a very long time on the tiling.
Can anyone tell me how many days would it take a moderately experienced professional tile installer to thinset (before grout) the shower that I described? Is there a going daily rate or are these projects usually a fixed price? I am in Southern California.
Assuming the studs are plumb and fixtures are in, does anyone know the going price to waterproof, hardiback, and tile my shower by a good professional in Southern California?
Thank you for any thoughts you might have and please let me know if this an appropriate question for this forum.
Leah
Unread 02-11-2011, 11:26 AM   #7
Interior Tile Solutions
Interior Tile Solutions's Avatar
Usually a small shower takes about 3 1/2 to 4 days.
Day 1 - Install shower pan, durock, waterproofing and then mud pack
Day 2 - Install tile on shower floor
Day 3 - Tile the walls
Day 4 - Grout
I price showers out according as to what's all involved, never a fixed price.
Robert
Your Friendly Neighborhood TileMan Making Your Tiling Dreams Come True One Piece At A Time...
https://www.houzz.com/pro/interiorti...tions/__public
Interior Tile Solutions is offline   Reply With Quote
Unread 02-11-2011, 11:37 AM   #8
My Dream
My Dream's Avatar
Robert, I'll assume your time line is for an experienced tile setter?
Frank
My Dream is offline   Reply With Quote
Unread 02-11-2011, 11:49 AM   #9
My Dream - Yes, an experienced tile setter..
An unexperienced person should take no longer than 7 days.
Robert
Unread 02-11-2011, 01:23 PM   #10
Leah F.
Leah
Thanks for your replies, so far.
Oh dear, I don't even want to say how many days more than the 7 days my unexperienced installer has taken (and how many days we have been without a shower)! He is charging $105.00 per day, so at 7 days, my shower would cost $800.00. Is that more than average or less than an average labor price of a new ceramic tile shower installation from pan to grout? Isn't here a price range for my So Cal region assuming no issues with tiles that are 4x4 but a simple design?
Leah
Unread 02-11-2011, 01:34 PM   #11
My Dream
My Dream's Avatar
Am I reading correctly that you believe it will take a total of 8 days to complete the shower install? $105.00 X 8 = $840.00. If that's the case and you're happy with the quality of work then I don't think that is a really high price. I'm from Canada so I shouldn't really comment but it's in my nature. Would have been nice to pay the same price and have it done in 4 but that's a moot point now.
Frank
Unread 02-11-2011, 02:02 PM   #12
The tiles themselves are an important part of the price. Got a pic of those tiles? Name? manufacturer? There are some days where we have 2 men working 8 hours to lay 2 square feet.
Unread 02-11-2011, 02:02 PM   #13
Shawn Prentice
$105 per day? Are you kidding? I'm guessing he is not licensed, not insured, doesn't pay taxes, i.e. he is operating his business illegally. Nobody, I mean nobody, in business for themselves can be legitimate working for $105/day.
Shawn Prentice is offline   Reply With Quote
Unread 02-11-2011, 02:10 PM   #14
Higher Standard Tile
Tile and Stone Contractor
Higher Standard Tile's Avatar
Who could actually run a legitimate business, pay taxes, and support a family on $105 a day!
If you had gotten a upfront bid from a licensed, insured, experienced tile setter you would have paid a lot more. But you would have a shower that will not leak, look really good, and be completed a lot faster, and you would have been supporting the legitimate local economy.
Edit- What Shawn said while I was slowly typing
Isaac
Higher Standard Tile & Stone
Maui, Hawaii
Unread 02-11-2011, 09:08 PM   #15
Your getting a very good deal if you get a good job that is done right, but for a professional licensed contractor that would be considered a slap in the face...
Robert
Small cracks in shower floor tile projectman Tile Forum/Advice Board 1 01-30-2007 11:42 PM
Shower Tile - Bottom row too small mike717 Tile Forum/Advice Board 14 08-13-2006 09:43 PM
Tile size on small shower floor - am I heading for trouble? :shrug: gof Tile Forum/Advice Board 8 02-13-2006 01:09 AM
Introduction and ? about how long it should take to tile shower JAYLUPARK Tile Forum/Advice Board 9 12-04-2005 07:06 PM
How long till walk (or shower) on sealed tile? jeaniebean Tile Forum/Advice Board 1 11-01-2004 06:15 PM
