Unread 01-28-2011, 01:42 PM   #1
cjensen63
Non-wet area with greenboard or cement board?
We will be putting 18x18 travertine tile about 4' up the bathroom wall in a non-wet area. We have greenboard but should we use cement board? The greenboard isn't up yet. We wanted to see which is best to do.
cjensen63 is offline   Reply With Quote
Unread 01-28-2011, 01:48 PM   #2
tilejoe
tilejoe's Avatar
If you have the option, my vote is for cement board.
Joe Lenner
Infinite Ceramic & Stone
www.infiniteceramic.com
NTCA Pennsylvania State Rep
CTEF Certified Installer #769
Unread 01-28-2011, 01:55 PM   #3
Trask
Oregon Tile Man
Trask's Avatar
Most of the GreenBoard type gyp panels that have a "water resistant" rating have a coating on them that acts as a bond breaker for thinset. Plain white sheetrock is fine so long as it never sees any water or moisture...I would use the Cement backer to be safe.
Trask Bergerson
Bergerson Tile and Stone
Astoria, Oregon
Unread 01-30-2011, 07:05 PM   #4
cjensen63
What can go wrong putting tile on greenboard in a non-wet area?
Thanks.
Unread 01-30-2011, 07:09 PM   #5
Cain
Cain
messed up quote but just above by trask
Cain Curtis
A Tile Experience
Certified Tile Installer #362
Cain is offline   Reply With Quote
Unread 01-30-2011, 07:18 PM   #6
Cain, if you'll go to the FAQ section (dark blue bar near top of page) and find the little tutorial on adding and properly attributing quotations, I think you'll find it pretty simple to do.
Unread 01-30-2011, 07:27 PM   #7
cjensen63
We'll go with the cement board then.
Wet cement board diggs Tile Forum/Advice Board 1 11-09-2010 07:48 PM
greenboard or cement board bryce1011 Tile Forum/Advice Board 12 04-20-2010 10:27 AM
Tear out Damaged greenboard or replace with Cement board Jbrain Tile Forum/Advice Board 10 11-14-2008 12:21 AM
Hanging wet cement board mcgee1163 Tile Forum/Advice Board 4 09-12-2007 07:51 PM
How to finish corner where cement board meets greenboard? rmx2501 Tile Forum/Advice Board 3 08-18-2006 01:03 PM
