Unread 10-01-2022, 08:22 PM   #1
Igman
2" Kerdi Board for Shower Curb
Looking at a modern 3" curb and was curious if anyone has used Schluter 2" Kerdi board? Thinking about using this as a curb with a Quartz sill on top. Any known reasons why this isn't a viable option? Planning on waterproofing with kerdi band just like a pre-fab curb.
Igman
Igman is offline   Reply With Quote
Unread 10-01-2022, 11:46 PM   #2
I haven't done it personally, but I know of several that have. You can use mortar for bonding, or Kerdi fix.
I'd use mortar since you'll have it on hand anyway.
Unread 10-02-2022, 09:08 PM   #3
Igman
Appreciate the comment. I did some additional research and there's a video from a Schluter rep that discusses using several different "pieces" to construct a curb. I am leaning towards trying it. I do plan on using mortar. I feel it's more secure going onto the subfloor. Thanks again.
Igman
Unread 10-04-2022, 09:15 AM   #4
Dan Marvin
Company Rep
We do also make a pre-made curb that is solid so you don't have to do any fabrication: https://www.schluter.com/schluter-us...KERDI_BOARD-SC
Dan - Schluter Systems
Dan Marvin is offline   Reply With Quote
Unread 11-27-2022, 04:13 PM   #5
Igman
Igman
Unread 11-28-2022, 07:29 AM   #6
speed51133
You can also take the schluter pre-made curb and cut it thinner if you don't want a 5in tall curb. A table saw is best so you get a nice, flat, parallel cut to the other side. Actually, you can tilt the blade to make one end slightly angled and give you the slope you want on the top of the curt(towards the inside of the shower. It does not need to be much, just enough so water will flow that way.
If the curb already has the orange membrane on it, (they sell it with and without, Just make sure you cut the bottom.
Kerdi shower curb vs kerdi Board curb Shady at Best Tile Forum/Advice Board 6 01-14-2018 06:04 PM
Shower Dam/curb. Kerdi board or kerdi membrane over sheet rock? Shady at Best Tile Forum/Advice Board 11 01-20-2016 09:44 AM
2" Kerdi board as shower wall questions geoErin Tile Forum/Advice Board 6 11-12-2015 08:46 PM
HELP! Kerdi shower curb mistake/"jolly" trim carsonsmom Tile Forum/Advice Board 8 09-29-2011 11:24 AM
A shower curb with cement board and Kerdi trihai Tile Forum/Advice Board 4 04-30-2007 01:41 PM
