Unread 07-15-2019, 07:32 AM   #1
13jmprice
6" x 36" tile grout lines
Tile leveling systems have 1/16" spacers but 6'"x 36" tile requires a minimum 1/8" grout line. How do you achieve that?
13jmprice is offline   Reply With Quote
Unread 07-15-2019, 07:52 AM   #2
Carbidetooth
Hmmmmm
Carbidetooth's Avatar
On floors I like Tavy spacers like these, on walls horseshoe style. I've never used lippage system as spacers
Peter
Unread 07-15-2019, 08:16 AM   #3
13jmprice
So I need to use 1/8" spacers and nor rely on the leveling system clips as spacers?
Unread 07-15-2019, 08:51 AM   #4
Carbidetooth
Hmmmmm
That would be my suggestion. Shouldn't affect the installation.
Depending on situation, I sometimes don't use spacers at all, but rely on "eyeballing".
Peter
Unread 07-15-2019, 09:11 AM   #5
13jmprice
Thanks. Installing about 1000 sf so I want to get it right. I've installed a fair amount of tile but this is my first time on the plank tile using a leveling system.
Unread 07-15-2019, 09:54 AM   #6
ItchyVols
2 weeks ago I laid similar size tile using the lash leveling system and separate 1/8” spacers in conjunction with each other. Worked like a charm.
Bradley
ItchyVols is offline   Reply With Quote
Unread 07-15-2019, 10:01 AM   #7
13jmprice
That's what i'm going to do. Thanks for the input.
Which grout coloring sealer do you recommend? "Grout Renew","Grout Refresh", or ? Fun2Learn Cleaning, Restoration and Sealing 1 02-22-2016 07:25 AM
Looking for advice on sealing wide "saltillo grout lines" sciguy Cleaning, Restoration and Sealing 3 08-15-2015 12:04 PM
Unused ceramic tiles with "etched" drip lines in them, possible to save? porge Tile Forum/Advice Board 7 01-24-2015 10:19 PM
Sealed grout "dissolved".."scratached" out with regular cleaning? emilyardore Cleaning, Restoration and Sealing 1 05-18-2010 06:15 PM
1/4" grout lines or very thin 1/8" Crazymo Tile Forum/Advice Board 5 03-25-2007 02:31 PM
