While RedGard can make a successful shower, it's hard to do while keeping the pan surface from getting damaged while installing the walls first...you're going to be walking all over it. RedGard, applied with the specified thickness, tends to look darker red when done properly, but color rendition on a photo is hard to get an accurate assessment from.
It looks like you used a clamping drain, and RedGard alone could easily leave some holes for water to escape. The instructions call for the use of their mesh tape embedded in the RedGard, then another layer of RedGard on top, then silicone caulk when applying the clamping ring.
