Go Back   Ceramic Tile Advice Forums - John Bridge Ceramic Tile > Other forums > Computer Training
Unread 04-29-2014, 11:35 AM   #31
ab319320
Restore computer to an earlier time
CX and all
I did not see anybody suggest this;
Click Start
Begin typing "Restore" When you get to "res" a pop up window will offer, "Restore your computer to an earlier time"
Click that line
Click "Open system restore" in the window that pops up
Click "Next" in the "Restore System Files and Settings" window
click box if needed "Show more Restore Points"
That should take you back to the point before the download.
Also I have learned to search each page when downloading a freebie for boxes checked that "They" want you to have. uncheck them.
ab319320 is offline   Reply With Quote
Unread 04-29-2014, 01:07 PM   #32
davem
davem's Avatar
That point about the check boxes is a good one Dan. A lot of malware/crapware can get installed along with the program that folks are actually trying to install. You have to be on the lookout for it. Read the screens, don't just keep clicking Yes/OK/I agree.
Unread 05-18-2014, 06:02 PM   #33
digitalshooter
Stop using AVG and Microsoft essentials! They both are poor!
Ed
digitalshooter is offline   Reply With Quote
Unread 05-18-2014, 08:04 PM   #34
jgleason
jgleason's Avatar
Hi Ed,
I used to use AVG but switched to MSE a few years ago. Never had a problem with it. Now Norton AV I could do without. That is a poor program!
All of this is just opinion though. You like a different program, recommend it. Stopping by to say AVG and MSE are poor isn't really helpful
without mentioning an alternative.
cx - It takes a little bit of knowledge but using a virtual machine is a great alternative. I run one with XP installed. Works great. VirtualBox by Oracle makes it pretty simple.
Unread 05-18-2014, 08:17 PM   #35
digitalshooter
Over the last 2 years, ALL of the PC's that I have serviced for malware or virus symptoms for clients, were infected while using either AVG or Microsoft Essentials. My decision to recommend to folks to not use them is based on my experience and also the online forums that rate AV's.
I personally use a 2 punch approach, ESET antivirus only and Malware bytes. Neither has let me down since I switch to them years ago when I left Norton.
Again, based on the websites that test these products and my own repair work for the last 2 years only, AVG and Microsoft Essentials don't cut it.
I did not recommend anything because I did not want to set off a debate since a lot of this depends on how and were you surf, whether you operate your pc with admin rights active or down load lots of free software with hidden nasties in it, just to name a few.
Ed
Unread 05-18-2014, 11:39 PM   #36
Not using either of those programs, Ed. Thanks.
Joe, the problem there is that you think everything about these computers is pretty simple.
Yeah, yeah, I do fully unnerstan that it's all ones and zeros, but that don't necessarily make it simple, eh?
Unread 05-19-2014, 07:05 AM   #37
digitalshooter
Misread your original post where you said your trial had expired and you downloaded..........
Either way, the info about AVG and ME, is valid.
http://www.av-test.org/en/home/ and click on the home square and read performance tests.
Ed
Unread 05-19-2014, 09:46 AM   #38
jgleason
jgleason's Avatar
Yep. Even with protection these things can easily open the door.
No argument that there are better products out there than AVG or MSE. My recommendation for MSE is based on my experience, YMMV.
cx - We should find some time to get a virtual machine set up for you. Wish I had been at Coverings this year, I could have gotten you up and running without any difficulty.
Unread 05-19-2014, 10:14 AM   #39
And I woulda been happy to let you do that, Joe, even though I'm not at all sure I fully grasp the concept.
As it stands, there won't be a really good opportunity to let you assume control of this thing, which I presume would be the plan, until after owl season. Maybe July sometime.
Unread 05-19-2014, 04:08 PM   #40
tiletime56
Shaun Haley Tile
tiletime56's Avatar
Send a message via Skype™ to tiletime56
Sounds like your virus problems have been solved, great! but still lurking in the background could be some more issues.
I would suggest and only a suggestion to run combofix (free program]which is a buggy program in itself, you must turn off all your virus protection programs before running, then let her rip , you'll be surprised with what it does. one thing to remember is when computer reboots itself after running the program it will say something like your system internet is ready for deletion, ignore this and reboot again then all will be fine.
Shaun
https://www.facebook.com/lists/22363...e/172655561618
Luv fat mud!
tiletime56 is offline   Reply With Quote
Unread 05-19-2014, 04:55 PM   #41
Originally Posted by Shaun
...run combofix (free program]which is a buggy program in itself,..
Scares me and I'm usually neigh onto fearless.
Unread 05-24-2014, 04:27 PM   #42
Super Anti Spyware is another free program that's good for getting a lot of trash off your computer.
Course, if you take everybody's advice on what you should have on your computer, it'll be full of anti-spyware and anti-virus programs, leaving no room for anything else.
Bathroom Woes tilemaster007 Tile Forum/Advice Board 6 04-26-2011 06:33 AM
Travertine Woes joel_carlson Tile Forum/Advice Board 16 04-04-2007 09:27 PM
Oh Woes Me MOSLEY Tile Forum/Advice Board 7 02-26-2005 03:33 PM
