Unread 05-06-2021, 11:53 AM   #1
patrick_here
Sealing ordinary concrete
Hello again everyone!
Perhaps this is a bit off-topic (if so, pardon me) but I'm thinking that there are probably people subscribed to this forum who have experience sealing an ordinary concrete garage floor ...in a garage where a car drives in and out every day.
I'm thinking that I would want to seal my garage floor to keep it from constantly generating dust. I know there are expensive coatings ...but some of them cant stand up to the thousand pound pressure of tires parked on them. I suppose that sealants might be a better intermediate solution to the problem of dusty concrete garage floors. Mine is not extremely dusty ...just wanting to seal the concrete. Any comments from guys experienced with this?
Patrick
patrick_here is offline   Reply With Quote
Unread 05-08-2021, 08:20 PM   #2
Hi Patrick, I guess the concrete could slowly erode enough to create a little dust. I could be wrong but I think that your tires are bringing in most of it. And, when it rains, the water your tires bring in isn't as clean as we would think. So when the water evaporates, a little dirt is left behind.
I once was talking to a guy that installs epoxy coatings on garage floors. We were talking about the area under the tires when the car is parked, that area seems to peel first. Don't know if he knew what he was talking about but he says the heat of the tires causes the peeling.
Unread 05-09-2021, 05:21 AM   #3
Gozo
Check on the garage journal forum. Lots of activity there on floor coatings and many vendors are active there on a daily basis.
On the “hot tire pickup”; I don’t think it’s a thing unless you’re drag racing right into the garage. I did mine in epoxy with a polyurethane top coat a decade or so ago. Epoxy still looks great; some peeling of the topcoat under tires and else where. I think it’s more where the water pools and gets into the microcracks. The topcoat is pretty much a sacrificial wear layer; I’ll get to to redoing when I have the spare time and interest (yeah, right).
Jeff
Unread 05-10-2021, 05:17 PM   #4
patrick_here
Gozo, thanks for mentioning the Garage Journal Forum. I didn't know it existed!
Patrick
Concrete Countertop - Sealing l_bones Cleaning, Restoration and Sealing 13 01-08-2014 10:26 PM
concrete floor sealing and grinding seanboyle Cleaning, Restoration and Sealing 7 02-13-2013 09:41 PM
Shot-blasting concrete and sealing?? cwilde72 Professionals' Hangout 10 05-06-2012 03:22 PM
Sealing over mastic on concrete KBO123 Cleaning, Restoration and Sealing 5 12-06-2005 07:27 AM
concrete sealing jcbrown Tile Forum/Advice Board 2 05-05-2005 08:20 PM
