Unread 05-05-2021, 02:28 PM   #16
Scott_M_FLA
Can you turn around large tile to finish wet saw cut?
For rental purposes, I can only locate a Imer Combicut 250VA Tile Wet Tile Saw to work on my 24" x 48" large format tiles. I need to make a rip about 42" long and this saw will only cut up to 28". (See: https://www.amazon.com/Imer-Combicut.../dp/B000NBBG2C)
Question: Can I cut to the 28" max, stop the saw, turn the tile around and then cut from the other end to meet in the middle and complete the rip? I think this ripped edge - if not perfect - can be hidden by some other trim work.
I'm not an experienced installer so I'm doubtful I can work a manual scoring/snap tile cutter - not sure if I can get a large format manual cutter anyway.
Any feedback regarding the feasibility of my workaround is appreciated.
Scott
Scott
Scott_M_FLA is offline   Reply With Quote
Unread 05-05-2021, 03:13 PM   #17
If you have a GOOD blade, you can, often make the "half cut," then flip the tile over on the back to make the finishing cut....all this with a fence, of course...
"They didn't want it good, they wanted it Wednesday."
Unread 05-05-2021, 03:36 PM   #18
Laz can explain but I think you could just trade ends (turn the tile around, not over) to finish the cut. Maybe I'm missing something.
Unread 05-05-2021, 05:06 PM   #19
Sure...you can trade ends....but the alignment has to be perty near perfect...
Unread 05-05-2021, 08:31 PM   #20
I agree, it needs to be real close. Hopefully the trim will hide any imperfections.
48x48 Large Format Wall Tile question whats_true Tile Forum/Advice Board 14 05-15-2020 09:37 AM
Kerdi/large format tile question jchurch Tile Forum/Advice Board 15 09-04-2019 05:24 PM
Large Format Subway pattern wont layout marlakem Tile Forum/Advice Board 4 07-19-2011 08:07 AM
thinset - large format kerdi, large format heat Rutili Tile Forum/Advice Board 2 04-07-2008 10:51 PM
Large format porcelain tile question Hamhanded Tile Forum/Advice Board 3 02-25-2007 01:26 AM
