Unread 03-13-2020, 12:20 PM   #1
Rodeo360
Sealing question for marble floor tile
I have searched and read about 100 threads here on sealing marble and I can't quite find the exact answer I am looking for.
We are tiling the floor with 1" hexagon white carrara polished marble tile (flecks of gray). We are using an unsanded dove gray grout. There is the same tile in the back of the niches, and we did not seal that before grouting.
The tile store is recommending sealing the tile before grouting and then once again 3 days post.
I keep reading here that sealing marble may be a mistake or at lease futile. I do want to seal the grout if possible.
Should I be sealing this marble at all? If so, before and after grouting?
Matt
Rodeo360 is offline   Reply With Quote
Unread 03-13-2020, 01:30 PM   #2
Metropolitan Ceramics
Sealing marble isn't a mistake, but using it for that application might be. White marble in particular is like a sponge and prone to discoloration from moisture that doesn't fully drain around the perimeter of the drain. It can also have yellowish minerals that migrate to the surface over time and make individual mosaics look discolored. I would strongly suggest that you find a porcelain mosaic with the same look and use that. If you're determined to use it, make sure that the drain is installed exactly as the manufacturer recommends, that all weep holes are open functional, and that the pre-slope is sufficient. Once all of that has been checked off the list, use a white mortar to set the mosaics and then seal them on the top and all four sides prior to grouting. Grout per the manufacturer's instructions and thoroughly clean all grout residue. Allow the grout to cure (the 3 day window they told you is a typical number) and seal again before using the shower. You also may want to consider a white grout instead of the gray although the pre-sealing should mitigate color migration.
Dan Marvin - VP of Operations
www.ironrock.com
Unread 03-13-2020, 02:13 PM   #3
Rodeo360
Thank you for the reply, Metro. For clarification, we are only doing marble on the bathroom floor, not a shower floor. The shower has a tub in it.
Matt
Help re-sealing tumbled marble floor s-mski Cleaning, Restoration and Sealing 3 10-08-2017 08:44 PM
Marble Mosaic Floor sealing doddsm Tile Forum/Advice Board 1 05-15-2017 11:18 AM
Sealing Marble Floor After Grouting 24valemd Cleaning, Restoration and Sealing 2 04-14-2016 11:39 PM
question RE: sealing polished marble when using a stainproof grout missmarble Cleaning, Restoration and Sealing 4 08-17-2005 06:31 PM
limestone floor tile sealing question Becky Tile Forum/Advice Board 1 03-19-2004 11:22 AM
