Unread 01-01-2019, 06:53 PM   #1
workhurts
Not tile but a miter cut question
Figure the pros would know how to do this.
Can't figure out a good way to tie in the molding going down the stairs so figured I'd just terminate and finish up the drywall properly.
I cut the thin strip of molding at 39 degrees and a 45 degree tilt but I'm having problems with the return.
Any idea what the saw needs to be set to and if my current cut is correct.
I want to terminate the trim so it's flush with the wall (but with a return).
Charlie
Unread 01-01-2019, 07:49 PM   #2
muskymike
muskymike's Avatar
Hi Ali, the easiest would be a plinth block. It is a block that you can make to run the trim to that is coming down the skirt board. You can bevel the edges on it too if you wish. I would make it flush with the corner cutting the angle of the stair skirt to the bottom of the block and make the block a bit higher than the trim piece
Musky Mike
Corrado Custom Tile
Kerdi Shower Specialist
New here? Check this out.
Unread 01-02-2019, 07:27 AM   #3
Certainly not a pro but I agree with Mike, Ali, a plinth is about the only way you can make it work.
I had a similar challenge while remodeling the living and dining room, and took me a lot of "stare at it" time to figure it out.
Unread 01-02-2019, 09:22 AM   #4
workhurts
Ugh. Thanks. If there's one thing worse than my tiling skills, it's my wood working skills.
The issue with a plinth or anything substantial is that corner wraps around again pretty quick and a 8-10" tall plinth would look great as then I still have to terminate the baseboard on the wall immediately behind the staircase into it.
Guess I'll be staring at the stair some more.
Charlie
Unread 01-02-2019, 11:38 AM   #5
That'sa tall base board, Ali, does provide for some head-scratching.
You could make a plinth to the height you need, bevel the top to match the angle of the baseboard on the riser where it dies into the back side of the plinth, fasten it to the narrow face wall, then wrap your base around it. Make it a feature.
Unread 01-02-2019, 05:29 PM   #6
workhurts
My baseboard is 5 1/2". I was thinking if I have to come off the stairs straight and then into a plinth, the plinth would have to be that high (8-10")
I really don't want a 'feature'. I don't like intricate wood work and prefer modern clean (industrial) lines.
The thin 1.5" molding doesn't have the exact same pattern as the baseboard. Similar but not exact. Suppose I could have ripped some baseboard down but gotta draw the line somewhere. I want this project to be done.
Charlie
Unread 01-09-2019, 11:31 AM   #7
dhagin
check here
https://www.bing.com/images/search?q...im&FORM=HDRSC2
a return to the existing base moulding, or a "stop" to die into may fit the bill.
dana
equipment needed to miter porcelain tile without chipping modusvivendi Tile Forum/Advice Board 15 02-17-2013 03:38 PM
Ceramic tile miter cut Arlington22207 Tile Forum/Advice Board 4 01-10-2011 09:20 AM
Back miter/grout line question John S Tile Forum/Advice Board 2 08-11-2007 08:26 AM
Tile Miter Cuts for corner joints... pgabriel Tile Forum/Advice Board 6 11-10-2005 02:22 PM
miter cuts in ceramic tile oma Tile Forum/Advice Board 5 06-25-2005 09:12 AM
