06-15-2015, 07:16 PM
#4261
Senior Contributor
The smell wasn't too bad. The super crumbly mudded walls disintegrated when touched so the air was filled with masonry fumes. The 4x4 tiles came off with a hammer in whole pieces, usually 4 or 6 at a time. The mudded walls were removed by pulling on the wire lath from the bottom and pulling away from the wall. The mud would crumble into pecan / pea sized pieces then fall to the floor.
Even with the exhaust fan on high, the doors taped shut and the shop vac filtering the air, we still spent an hour vacuuming and dusting before we left for the day. Will do more tomorrow as the walls now have a film of partially vacuumed off dust coating them.
3x3 shower on the second floor took 9 hours to demo mostly due to the very crampt space (for Texas standards). . No need to go to the gym tonight
Paul 1
06-15-2015, 07:53 PM
#4262
Central Texas Tile Guy
Heck, the prep on that shower looks better than a lot of em! That's still not necessarily a good thing though...
07-23-2015, 01:13 PM
#4263
Check out these beauties from my recent master and guest bathroom full redo. The first one is the decorative tile going up to my shower door in the master bath. The second one is around the tub in the guest bath. My terrible contractor used the phrase a lot "once I get this caulk on there you wont be able to tell". We can tell....a blind man could tell.
Patrick
07-23-2015, 03:58 PM
#4264
If he's proud of his work, Patrick, do post his name along with your photos.
07-23-2015, 04:30 PM
#4265
Not So Senior Contributor
Oh yes Patrick...do tell us!
Craig
Commercial Tile Installations
KEEP CALM and TILE ON
08-08-2015, 06:01 PM
#4266
Good job Hollywood CA...and its probably rotated...sorry
Don
09-09-2015, 09:40 AM
#4267
Senior Contributor
Went to give a new construction estimate today. I don't think we are going to get involved with this job.
1- No pre-slope, but instead some very soft glue. Maybe roof patching tar
2- Sealed the weep holes closed
3- No blocking for the liner
4- Dam corners not glued properly allowing leaks
5- No door jamb waterproofing
6- Hardiebacker installed with a few drywall nails
7- CBU taped and floated with drywall mud
8- Studs not notched for the liner
9- Floors so out of level the hardwoods will be a mess at the doorways
10- Doors set too low
11- No bullnose / edge pieces for the hand cut 3/4" thick tiles
12- Tubs not set
13- Drywallers not finished
14- No air conditioning
15 - Needs this done yesterday (see #13)
16- The exterior decks are level, if not sloped to the house
17- Not enough flashing exposed (if any) along the decks to allow for mud bed
Paul 1
09-09-2015, 09:43 AM
#4268
Senior Contributor
more wonderfulness
Paul 1
09-18-2015, 08:44 AM
#4269
Hmmmmm
Run Paul, run! Appears to be problems looking for an owner...
Peter
09-20-2015, 07:21 PM
#4270
Senior Contributor
After I explained all his problems and what all needed to be done to fix them all ..... he never called back or emailed the building plans.
Gee what a surprise
Paul 1
09-21-2015, 07:33 PM
#4271
Did you know that they already "prepped" it, Paul, or was that a surprise?
I've gotten to a point that I won't mess with jobs unless I do the prep. Other peoples idea of "tile ready" may not be the same as your own...
10-05-2015, 06:33 AM
#4272
this thread doesn't get near as much traffic as it should.
c'mon guys show us those really bad ones!
Pfeff
10-06-2015, 05:20 PM
#4273
Leaking shower. First time seeing anything like this. The shower base was built from 2x4s and foam. They literally bent the middle of the 2x4s by shimming the outer edges to make a pitch. Owner said they initially called the person who did this job about the leak. Apparently he opened up the ceiling underneath and shot more foam around the shower base. Obviously that didn't last long.
Vi
10-06-2015, 05:40 PM
#4274
Senior Contributor
Does bad electrical work count?
We demo'd a bathroom wall today to find this little bit of butchery
on the other side there were only 4 bare wires covered only by drywall mud & paint
Paul 1
10-06-2015, 06:08 PM
#4275
Holy crap, Vi. That is pretty much worst case scenario.
And yes, paul. That is custom work belonging in this thread. People who do crap like that make all our lives harder.
I'm Dan.
I am the master of my fate:
I am the captain of my soul.
-"Invictus" by William Ernest Henley
