Unread 04-07-2014, 08:52 PM   #4096
mullet
mullet's Avatar
lol, you guys are the exception. I think people that navigate to these forums are always searching to find new techniques on how to do things better.
chuck
my first Kerdi Shower
Unread 04-11-2014, 08:12 PM   #4097
Brady Wimer
Local hotel laundry room getting some new tile installed...you may want to shield your eyes. A friend took this and showed me at lunch. I almost spit out my food from laughing.
Brady (not a trial lawyer, but a tile lawyer--it's a rare combination, I know).
Brady Wimer is offline   Reply With Quote
Unread 04-11-2014, 08:16 PM   #4098
Paramount Installer
Chicago Tile Contractor
The part about washing the grout after you pump it in the joint on the grout bag was probably worn off!
George
"Associate with men of good quality if you esteem your own reputation; for it is better to be alone than in bad company."
George Washington
http://www.paramountinstallations.com
Paramount Installer is offline   Reply With Quote
Unread 04-11-2014, 08:28 PM   #4099
evan1968
Not So Senior Contributor
evan1968's Avatar
They skipped that last crucial step.
"Did you wash?"
"No, thought you did!"
Craig
Commercial Tile Installations
KEEP CALM and TILE ON
Unread 04-11-2014, 09:13 PM   #4100
Wayne67vert
Tile Contractor
Wayne67vert's Avatar
Send a message via AIM to Wayne67vert Send a message via MSN to Wayne67vert Send a message via Yahoo to Wayne67vert
They had the door propped open and didn't see where they forgot to clean.
Wayne
Wayne67vert is offline   Reply With Quote
Unread 04-12-2014, 06:37 AM   #4101
Eschbach
Tile Contractor-Virginia
I guess they were going to clean it later
www.eschbachrenovations.com
Virginia Installer of Schluter Kerdi and Kerdi Board Waterproof Showers
Excellence is no accident
Eschbach is offline   Reply With Quote
Unread 04-12-2014, 06:54 PM   #4102
K_Tile
Member of Million SF Club!!
Current project: Commercial Fitness Center
This steamer was only 4 years old.
When I first demoed the floor I thought the waterproofing was just loosed laid pvc with tile directly bonded to it. The sheet membrane was completely loose from the slab and very smooth. Once I cut the perimeter wall and around the drain, the membrane rolled up in a sheet (tile still attached). Upon further inspection I noticed fabric indentation in the thinset (see photo)
So to my amazement everything seemed to be installed correctly. An orange CPE material, thinset to concrete slab with blue caulking at seams and corners.
This is the first time I have ever seen the polyester fabric disintegrate! Once that goes there is nothing left to hold on.
Unread 04-19-2014, 08:02 PM   #4103
lou432
Tile Man -- Southern New Hampsire
lou432's Avatar
Nothin new here !! Attended the Schluter camp at the CTEF 12 r more years ago and the guy that did this job was there, when I recognized him as a local in my area and noticed that he paid no more attention at the seminar than a blind person .
Shower was leaking ,tore it out just above the seat. Kerdi on some walls to 2 feet above pan on sheetrock. Seat kerdied no inside or outside corners or dog ears or k-fix. K band on foam tray as needed but no Kerdi on tray .No thinset under drain to tray and 1/4x1/4 trowel used to set tray on plywood. Granite sill adhered to 3 stack 2x4`s with no rock or kerdi wrapped or corners . And to top it all off wall tile on kerdi set with mastic ....Rot everwhere !!! Out to the floor tile outside shower Ditra set good in thinset but tile pulled up with screw driver . No filling of trapezoids no back buttering of 18x18 tiles and 1/4x1/4 trowell used...
Every thing done wrong !!
Some of the other pics wouldn't load so these are the only ones that loaded but you`ll prolly get the Idea!!
Louis
White sand+ blue water .
Find the grace in things that you can`t change, and help some body if you can!
"Van Zant"
I`d rather be on my Harley thinking about God than in Church thinking about my Harley .
My Tile Work Pictures
lou432 is offline   Reply With Quote
Unread 04-28-2014, 06:31 PM   #4104
Calgary Dave
So, with work just getting busier, I had to hire some guys. Finding a "good" guy, is another thing!!
So this guy answers my ad and tells me he's got close to 30 years laying tile. A little older than me, trained in mudwork, does it all, greatest around... yaddah, yaddah, yaddah.
"Great, can you install Schluter systems as well?" I ask.
"Oh yeah, pfft..no problem".
So I put him to work. First thing I notice is he installs all the big sheets before doing his corners. Ooookay....
Then I notice he's got thinset EVERYWHERE...all over the walls, himself, etc. He's got HUGE speedbumps going on wherever the 6" strip of kerdi is going.
Forgets a couple of outside corners...then I notice there's no drain in a unit he says is finished.
"Where's the drain?"
"Oh, I put those in afterwards"
I manage to fix those mistakes, and then proceed to let him start tiling. Forget the fact that it took him over TEN HOURS to put up 6, (no make that 5, one fell off, that he never replaced) pieces of 12x24 on the ceiling. (My son did the same ceiling in an hour and a half).
But this is the quality I came back to: (He's now threatening to lein the building unless I pay him his entire invoice).
Calgary Dave is offline   Reply With Quote
Unread 04-28-2014, 07:34 PM   #4105
jwmezzanotte
jwmezzanotte's Avatar
Nasty Dave!
And that right there is why I dont feel like hiring. What a nightmare.
Unread 04-28-2014, 09:22 PM   #4106
set
set's Avatar
bummer Dave, tough to find even semi decent help, never mind good help. ive been needing another guy for sometime now, but just don't want the hassle and stress. sorry to see the mess he left for you , hope you get it all good for your client.
Dan Chamberlain
set is offline   Reply With Quote
Unread 04-28-2014, 09:25 PM   #4107
set
set's Avatar
must just kill you to post one of your own jobs in this post !!!!!! SORRY MAN (someone had to say it)
Dan Chamberlain
Unread 04-28-2014, 10:04 PM   #4108
jwmezzanotte
Maybe this will help.
I was doing a backsplash last week for a customer I did a tub surround for about 6 years ago (i think). Havent seen it since then. Thats way back when I used to know I was good, before I found this forum. Lol "good"
I did this one myself...
See any lippage?
Unread 04-28-2014, 10:08 PM   #4109
You mean that wasn't supposed to be a 3-D installation ?
Unread 04-28-2014, 10:14 PM   #4110
jwmezzanotte
Skillz
Sadly, that was "good" by rupert standards. Still is. I wont/dont do crap like that anymore, pretty much a result of hanging out on this forum. Id do a mud job on that if I had to do it again.
Id like to go back and suggest to myself a mud job.... "Whats mud?"
Absolute worst tile finishing job pitterpat Professionals' Hangout 17 04-02-2007 07:12 PM
worst of the worst... botched jobs Dan O'Connor Tile Forum/Advice Board 5 02-22-2007 03:21 PM
best and worst tile saw in $300-$500 range LinLee Tile Forum/Advice Board 9 01-30-2006 01:50 AM
best and worst tile saw in $300-$500 range johnnyaico Tile Forum/Advice Board 10 01-27-2006 03:05 PM
The worst job................ opiethetileman The Mud Box 6 10-08-2004 10:48 PM
