Unread 02-15-2009, 11:31 AM   #1
mean jean
curbless shower
We are trying to install a curbless shower on our second floor - we found we have a w truss style system - how do we lower the shower area floor in order to build up to the regular height and have all the floor one level? we are installing an aco trench drain so we know we need to slop the shower "area" 1/4" per foot.
mean jean is offline   Reply With Quote
Unread 02-15-2009, 11:47 AM   #2
You cannot modify trusses. Trusses carry the load in the top and bottom chords, and if you cut either one, you destroy the truss.
You can get trusses with a section recessed like you want. These simply have extra material on the top chord where the recess isn't. These trusses are custom fabricated and would be build into the house as it was being built.
Sorry, but I wish there was an easy answer for you.
Unread 02-15-2009, 12:04 PM   #3
mean jean
thank you for your quick reply - at this point in the constuction we have the sub-floor cut out in the shower area - what the remodeling guy wants to do is install durock in the shower area - put another layer of plywood on the rest of the bathroom floor - then durarock on top of that - then he wil start tiling and when he getws to the shower area, he will start his sloping to the drain which we be on the plumbing wall. Is this the right way to do it?
Unread 02-15-2009, 12:14 PM   #4
Dave U.K.
Pro Tile Fixer....UK...
Dave U.K.'s Avatar
We in the uk use a former/tray suited to these type of installations..
Take a look at THIS for a better idea what i mean..
Dave..
Dave U.K. is offline   Reply With Quote
Unread 02-15-2009, 12:19 PM   #5
Dave U.K.
Dave U.K.'s Avatar
Some more for you to look at...
Here.
Here.
Here
There are loads of different systems about to save using the curb method, giving that more open feel to a shower area..
Dave..
Unread 02-15-2009, 12:21 PM   #6
Dave U.K.
Dave U.K.'s Avatar
If you would like more info onthese type of wetrooms then i can get loads of info for you...
The curb method is great but in the uk we are moving over to the more spacious look..
But the lads on here will some very good advice on sytems they use as well..
Dave..
Shooters Bath / Shower project! Questions from the new guy? Shooter Tile Forum/Advice Board 81 12-13-2009 09:17 AM
Is this a good idea (curbless shower)? dancogswell Tile Forum/Advice Board 22 05-30-2007 04:35 PM
curbless shower. how, if possible? cookevillain Tile Forum/Advice Board 9 06-30-2006 12:17 AM
Shower leak/questions phenom Tile Forum/Advice Board 8 05-05-2005 05:41 AM
Curbless steam shower project help Rodonisle Tile Forum/Advice Board 2 02-28-2005 08:39 PM
