Unread 06-03-2009, 07:22 PM   #766
The Kid
The Kid's Avatar
My problem is the wedi drain just held by a compression fitting. Brian, what are your thoughts on the drain? Im afraid of its longevity, although they do offer a 10 yr system warrenty so.
Jeremy
Cascade Tileworks,llc
Licensed, Bonded & Insured
WA Lic# CASCATL894QA
The Kid is offline   Reply With Quote
Unread 06-03-2009, 07:34 PM   #767
Old World Tile and Marble
brian where are you buying the wedi board? how far from albany ny are you?
jason
Old World Tile and Marble is offline   Reply With Quote
Unread 06-03-2009, 08:00 PM   #768
gueuzeman
Jason, Johnson city is a suburb of Binghampton, hope I spelledthat right, Brian.
gueuze- just finishing dinner with fresh steamed swiss chard from the garden!
gueuzeman is offline   Reply With Quote
Unread 06-03-2009, 08:01 PM   #769
Scottish Tile and Stone
close up of the slate mosaics..
shower floor in (dis-regard all the smudges hasnt been cleaned yet)
couple shots of bathroom
Scott.
www.scottishtileandstone.com
Laticrete hydroban showers
Mud set stone.
Unread 06-03-2009, 08:55 PM   #770
bctile601
Tile Contractor
bctile601's Avatar
I've always been a little iffy on the connection of the walls to the base, being nothing more than the adhesive along the bottom of the panel.
That's not entirely true, the system involves a rabid cut in the pan. If you happen to need to modify the pan to fit ( most do ) then the rabid needs to be re-cut. Then your panels slip inside the nasty caulking nestled in the rabid.
The drain is definitely not the best, but it does work. After completeing the steps, the riser pipe and rubber bushing are tight for sure, I then will wipe some of the urethane over top to keep water / soap off the rubber. It's the same drain as any of the fiberglass units out there, and they seem to hold together even with the flexing they allow.
The fact is I'd rather build a Kerdi shower with a Kerdi drain, this was requested by this builder, there is another one of my builder's using it, I've also used it on my own jobs and I'll continue to use the system until the Kerdi board comes out. No leaks yet, don't think there ever will be.
I'm getting the Wedi from Vestal Tile, they deliver to Albany. Fran is the key contact there.
Brian---
No one cares how much you know until they know how much you care
bctile.com
bctile601 is offline   Reply With Quote
Unread 06-03-2009, 09:31 PM   #771
gueuzeman
Great pics and info, Brian. Thanks.
I'm uploading a video to youtube now, link pending. Don't say you weren't warned......
gueuze
Unread 06-04-2009, 12:40 AM   #772
dhagin
that's a nice lookin shower there scottyb. those colors look good together with the schluter.
dana
Unread 06-04-2009, 02:48 AM   #773
oogabooga
Scotty, that sure looks sweet. Think I might steal that idea in fact.
Rob.
oogabooga is offline   Reply With Quote
Unread 06-04-2009, 05:19 AM   #774
thanks dana and rob.
rob go ahead and use the idea. homeowner saw it in a pic.
Scott.
Mud set stone.
Unread 06-04-2009, 03:44 PM   #775
custombuilt
Here are a couple shots from some of my projects....
Did hardwood for a builder, who had hired a tile guy to do his shower. It was BAD! Liner 3 inches up the walls, durarock nailed all over the inside of the curb, no preslope, weep holes plugged ect.
I didn't have the camera to get any pics, but I tore that mess out of there as fast as I could.
Here is how I re-did it-
Jason W.
Superior Construction
Quincy, IL
Unread 06-04-2009, 03:52 PM   #776
custombuilt
Darn mosaics were thinner than the wall tile (what else is new?) So I had to build it out with my fancy tool there
Finished up today, everything but the glass inserts, which the builder back-ordered and doesn't have coming in till monday.
Yes, I caulk all my corners
Jason W.
Quincy, IL
Unread 06-04-2009, 03:55 PM   #777
custombuilt
Got a call from my helper, needed help doing a little mud in a basement....
Jason W.
Quincy, IL
Unread 06-04-2009, 06:24 PM   #778
Davestone
Florida Tile & Stone Man
That's always a tough call, put the accent line above the soap shelf or below.
http://Davestonestile.com
Unread 06-04-2009, 07:54 PM   #779
jason wheres the liner? Or an i not seeing it?
Scott.
Mud set stone.
Unread 06-04-2009, 09:33 PM   #780
Scott,
if it's a preslope, liner, final bed you wont see the liner.
Shower Progress Pics Electrician Al Tile Forum/Advice Board 15 07-12-2011 11:38 PM
Noob - questions and (eventually) progress pics hamfist Tile Forum/Advice Board 1 01-29-2011 09:19 AM
Kerdi shower in progress -- 5 pics 4 questions ritch Tile Forum/Advice Board 4 04-20-2009 11:32 PM
Another job finished up (pics) Chris H Tile Forum/Advice Board 10 04-01-2008 06:21 AM
