Unread 11-07-2010, 05:35 PM   #6901
silvercitytile
silvercitytile's Avatar
nice work Joe!
Castillo Construction
Unread 11-07-2010, 07:46 PM   #6902
JC
With bad walls and big tiles many times you can pull a piece back off only to find that due to one corner being too high there is no thinset transfer at all in other spots. Very common
My question is how does the TLS fix that..or is it just that once you set the tile and tighten it up you never bother to check for coverage since your not pulling the tile back off?
Or do you put up each tile and pull each piece back off, inspect for coverage(and of course add if need be) then put it back up this time with the TLS?
what gives, unless your doing something special the the TLS is not going to bend the tile to conform to the walls and take out naturally occurring low spots that happen.
JC is offline   Reply With Quote
Unread 11-07-2010, 08:42 PM   #6903
tilejoe
tilejoe's Avatar
Jim, I know your concerns. It is a feel thing though. I know when there isn't enough. We all "know" when we have to take one down. I will say that anyone comfortable spotting walls, shouldn't take issue though.
Joe Lenner
Infinite Ceramic & Stone
www.infiniteceramic.com
NTCA Pennsylvania State Rep
CTEF Certified Installer #769
Unread 11-08-2010, 07:58 AM   #6904
jondon
jondon's Avatar
posted by Joe:
I feel the same way as Joe, like someone who sees you do something and they never done it. From experience you know if you don't have enough thinset under that tile. When you go to tighten the straps, if that tile pulls in too much, you know you gotto unstrap it and add.
Yes you should not use this system if your walls are way outta plumb. In that case you should be fixing the walls, or mudding them. And yes, mud shower wall= no TLS needed, same for mud floor. Redundant to use both.
If your wall has a few dips, TLS is great. Bulges not so great. Preparation of your walls is mission essential as it is always for tile installation. Of course its not for every installation but in the times I have used it in a shower project I am glad I did. In my 250 sq. ft. marble shower, I had zero lippage cause a the TLS, well maybe a little lippage on the ceiling cause no way was I using it 10 ft up on a ceiling. So it has its place. A learning curve like anything else
Jon Donmoyer
JD Tile
CTEF Certified Installer #825
Unread 11-08-2010, 03:46 PM   #6905
alacrity
alacrity's Avatar
From a couple pages ago, addressing the gap...
Originally Posted by Chad
Hope that granite dam has a serate piece in that gully so they could pitch the water out of there.
It's tough to see, but there's a 2" gap between the bench and curb, still a bad design. (not mine)
Originally Posted by Peter
Note to self , get a new camera.
That's my iphone, I don't normally take a camera to work.
Here's a shower surround I did over the weekend, and a backsplash I did today, Nothing fancy, easy money.
Eric
alacrity is offline   Reply With Quote
Unread 11-08-2010, 04:29 PM   #6906
jondon
jondon's Avatar
posted by Eric:
Nothing wrong with easy money, least someone is doing it. Nice clean crisp work there Eric, glad to see you're keeping busy Currently taking a break and giving my knees a break, too many floors in the last couple months for me
Jon Donmoyer
JD Tile
Unread 11-08-2010, 05:00 PM   #6907
tennesseetile
Glue down wood
Just some engineered glue down wood. Know its not tile, thats for next week.
gram
tennesseetile is offline   Reply With Quote
Unread 11-08-2010, 06:40 PM   #6908
Mountain Tile
Pashley Tile
Here's a Few.Name:  cool jobs 004.jpg
Name:  cool jobs 002.jpg
Name:  cool jobs 005.jpg
Chuck
wwwpashleytile.com
Mountain Tile is offline   Reply With Quote
Unread 11-08-2010, 06:45 PM   #6909
Mountain Tile
Pashley Tile
And a Few MoreName:  cool jobs 010.jpg
Name:  cool jobs 011.jpg
Name:  cool jobs 015.jpg
Name:  cool jobs 014.jpg
Name:  cool jobs 012.jpg
Chuck
wwwpashleytile.com
Unread 11-08-2010, 06:52 PM   #6910
irish tileguy in michigan
Tile Contractor -- S.E. Michigan
irish tileguy in michigan's Avatar
Very nice Chuck
Steve
Maloney Tile and Marble
Farmington Hills & Livonia, Mi.
Laticrete Hydroban & Schluter Kerdi shower installs
Custom installation of Tile and stone
irish tileguy in michigan is offline   Reply With Quote
Unread 11-08-2010, 07:00 PM   #6911
is thats Chinks steaks house ?
you sneaky thing !
Unread 11-08-2010, 07:18 PM   #6912
jondon
jondon's Avatar
Nice to see something a lil different Chuck, I really like all the materials used on that job. The tile and feature area go great with those detailed cabs. I like the way you did the shower and tub area as well. High End Craftsmanship in that house
Gram, nice, I like how the horizontal boards are stepped down to meet the vertical ones if that is the right way to esplain it. Guess it depends on the angle your looking at the floor.
Jon Donmoyer
JD Tile
Unread 11-08-2010, 07:42 PM   #6913
tilejoe
tilejoe's Avatar
Lookin Good Chuck! Glad a real tile guy is getting some new construction in our area.
Joe Lenner
Unread 11-08-2010, 08:05 PM   #6914
Arimert
Arimert's Avatar
Nice work chuck.
Amos
ADR Tile&Stone. Certified tile installer#852
Arimert is offline   Reply With Quote
Unread 11-08-2010, 09:19 PM   #6915
Chuck looks good man, I like that chiseled stone floor in that kitchen. That showers got some pitch.
Eric,
Nice work man you got some skill for your age.
Shower Progress Pics Electrician Al Tile Forum/Advice Board 15 07-12-2011 11:38 PM
Noob - questions and (eventually) progress pics hamfist Tile Forum/Advice Board 1 01-29-2011 09:19 AM
Kerdi shower in progress -- 5 pics 4 questions ritch Tile Forum/Advice Board 4 04-20-2009 11:32 PM
Another job finished up (pics) Chris H Tile Forum/Advice Board 10 04-01-2008 06:21 AM
