10-30-2010, 05:55 PM
#6781
only in California !
resĀ·in (rĕz'ĭn) pronunciation
n.
1. Any of numerous clear to translucent yellow or brown, solid or semisolid, viscous substances of plant origin, such as copal, rosin, and amber, used principally in lacquers, varnishes, inks, adhesives, synthetic plastics, and pharmaceuticals.
10-30-2010, 05:56 PM
#6782
Tile and Stone Contractor
Ive only ever used wood, then a flat. Never even considered a mag for pans.
10-30-2010, 07:28 PM
#6783
Tile Setter
I use various mud tools,dependant on the job/size. Mag is nice for bigger areas as not only can you pack with it,you can rub up with it after gaining the exp.
Wood/fiberglass floats allow you to rub up the mud,and as Brian mentioned,feed the chickens(sprinkling the mud on top) to fill minor voids,prior to final slick down.
IMO,each tool has it's pros,when used in the right application.
Rich
10-30-2010, 07:57 PM
#6784
I've always liked magnesium floats and wood floats for deck mud, and steel trowels, too. Sometimes one of each onna same floor. Different strokes, eh?
10-30-2010, 07:58 PM
#6785
Making Cents of It All
Levi you use a wood float to compact the mud too. That's what we use a magnesium float for then tool with a resin or wood float.
Brian its still not plastic
10-30-2010, 08:02 PM
#6786
I keep a bucket of water handy for packin and if I keep the wood float clean and wet mud won't stick to it. I pack it with wood, shape it and tool it with wood, then take a flat trowel and put a nice finish on it.
10-30-2010, 09:09 PM
#6787
Utah Tile Contractor
I too am a wood float guy. Been using the mag more though cause my wood floats are getting pretty bad. If your mud isn't too wet the wood floats are great and not much mud sticks to them. If I ever see one of them resin floats I might buy one to try, no place I frequent stocks them and I don't think to order one until I already need/want it.
Once packet and formed I hit it with the mag or steel trowel to embed the sand and give it that smooth finish then throw some plastic over it and let the magic begin.
Bryan
EX Tile Contractor
Positive Tile and Stone
Salt Lake City, Utah
10-31-2010, 06:28 AM
#6788
Levi I see pressure treated.
I have tried mag floats, resin floats (Brian I'll give you mine next time you come up) and even lightweight urethane foam floats. Yet each time I go back to the wood float.
If you keep packing the mud with you wood float, its going to split right in half. Just wait...
10-31-2010, 07:01 AM
#6789
OK, so it wasn't just me.
10-31-2010, 07:20 AM
#6790
posted by Gueuze
I think Rick could be Dave Gobis's right hand man on tile forensic consulting, he has that Eagle Eye to find these things, I know he was taught that way
10-31-2010, 07:53 AM
#6791
not interested in a mag or resin. I'm fine with the wood float. I buy one every couple years or so and keep a old one around in case I break one, never have so far.
10-31-2010, 08:15 AM
#6792
Tile Contractor -- S.E. Michigan
Same as Brian, i use 2 different size wood floats and hit everything with the steel to finish.
Steve
Maloney Tile and Marble
Farmington Hills & Livonia, Mi.
Laticrete Hydroban & Schluter Kerdi shower installs
Custom installation of Tile and stone
10-31-2010, 10:54 AM
#6793
Oh OK Brian you were in post #6779
The wood floats are nice you need to sand the corners to break em in faster and they turn black after the initial burn from the cement.
10-31-2010, 11:05 AM
#6794
I broke one last week (wood float).
10-31-2010, 11:18 AM
#6795
posted by Mark:
Mark you know breaking one over your helper's head doesn't count
All this talk a floats, I think when the Mud Class Movie comes out we should add a little extra documentary on floating, that is with both feet on the ground
