Unread 02-06-2013, 05:42 PM   #15781
the wider trowel lets you spread a nice smooth flat line.
no humps, swirls or high spots to mess with your setting a flat tile.
and when you notch out your only taking a little off the edges, enough
for the thinset to press back into the void as you set it and not come
up through your grout joints.
I do marble the same way so I dont get squeeze out.
Unread 02-06-2013, 05:54 PM   #15782
Arimert
Arimert's Avatar
I have 2200 ft of plank coming up,ill be setting it with 4xlt rapid set.i will use a 1/2x1/2" notch trowel and flat coat all planks.
Sent from my DROID BIONIC using Tapatalk 2
Amos
ADR Tile&Stone. Certified tile installer#852
Arimert is offline   Reply With Quote
Unread 02-06-2013, 05:58 PM   #15783
Chad Deiter Company
Making Cents of It All
Chad Deiter Company's Avatar
Send a message via Yahoo to Chad Deiter Company
Dang 2200sqft that's a bunch
Chad from CDC54.com " You Dream It and We Create It "
Southern California Custom Tile and Stone Installation
Chad Deiter Company is offline   Reply With Quote
Unread 02-06-2013, 06:04 PM   #15784
Originally Posted by Donnie D.
i know about cutting the thinset off around the edges of the tile but i feel that it could possibly leave a void there with no thin set
Donnie,
your guy was putting down big plops of thinset and setting the tile on them.
I would think you would have more voids from those globs.
that's a lot of thinset for under those planks to ooze up into the grout joints
your better off spreading a nice smooth flat line, cutting out the edges,
back buttering and then setting the plank.
Unread 02-06-2013, 06:37 PM   #15785
Donnie D.
I love Mud!
ceramictic
ok i understand now..yea we had to, the slab was very out of level and not flat..next time we will use a self leveling cement
Don
Donnie D.'s Tile&Remodeling LLC
-bathroom remodeling,tile,interior doors,molding,drywall..
from remodeling to repairs
out of central jersey
https://www.facebook.com/DonnieDsRemodeling
Donnie D. is offline   Reply With Quote
Unread 02-06-2013, 06:39 PM   #15786
yeah, floating or flashing the floor flat or using an SLC will save you time and headache when setting.
Unread 02-06-2013, 06:45 PM   #15787
Donnie D.
I love Mud!
you got that right man!
Don
Unread 02-06-2013, 08:32 PM   #15788
Arimert
Arimert's Avatar
its a hotel that needs to be updated,its only a bout 5 years old but the franchise is changing looks.i also have a 1000 ft on a home to do as well and 650sf of 9''x36'' planks.
Amos
Unread 02-06-2013, 08:41 PM   #15789
reefone
tile setter
I just ripped out some real hardwood on Monday to replace with wood look plank tiles. Lol. Ill get some pics later this week.
Jerry
tile setter 12yrs exp.
Unread 02-06-2013, 08:41 PM   #15790
I worked with a guy who asked me why I did that with the margin trowel around the perimeter of the tile, it helps from the oozing.
Unread 02-06-2013, 09:29 PM   #15791
jwmezzanotte
jwmezzanotte's Avatar
I do the same, for the same reasons. And if any does ooze out i run my margin trowel through the grout line and clean it out. Id like to tell you that i then clean the tile with a sponge rather than my finger and then my pant leg, but that would make a liar out of me
I ruin a pair of jeans/job, its a bad filthy habit, but im working on it
Unread 02-06-2013, 09:49 PM   #15792
definitely, you know from doing a lot of marble up there in Philly.
Unread 02-06-2013, 11:52 PM   #15793
Higher Standard Tile
Tile and Stone Contractor
Higher Standard Tile's Avatar
Brian and Rick- How is the coverage on the corners when you lift a tile to check coverage?
Isaac
Higher Standard Tile & Stone
Maui, Hawaii
Unread 02-07-2013, 07:32 AM   #15794
you are only cutting a small groove against the tile ahead of you
with the corner of your margin trowel. not a deep wide valley.
and in reality its not taking thinset out, its really plowing it off the tile edge and moving it out of the way. when the tile is set the thinset pushed back in the void.
I also do the when using the TLS so I dint get squeeze up under the caps.
Unread 02-07-2013, 10:09 AM   #15795
Arimert
Arimert's Avatar
Florida tile ledger stone for a fire place.
Amos
Shower Progress Pics Electrician Al Tile Forum/Advice Board 15 07-12-2011 11:38 PM
Noob - questions and (eventually) progress pics hamfist Tile Forum/Advice Board 1 01-29-2011 09:19 AM
Kerdi shower in progress -- 5 pics 4 questions ritch Tile Forum/Advice Board 4 04-20-2009 11:32 PM
Another job finished up (pics) Chris H Tile Forum/Advice Board 10 04-01-2008 06:21 AM
