Unread 11-19-2012, 06:32 PM   #15106
Phil, I'll bet a nickel that the tiles came off so easy that cutting the sheetrock and pulling the tile and sheetrock together might would have resulted in a chipped tub. Just a guess though.
Okay, what Paul said.
Unread 11-19-2012, 06:33 PM   #15107
reefone
tile setter
paul i always like to look at your pics. seems like you never do any standard work which is nice. wish that was all i did $$$.
Jerry
tile setter 12yrs exp.
Unread 11-19-2012, 06:33 PM   #15108
Arimert
Arimert's Avatar
wow must be nice.
Amos
ADR Tile&Stone. Certified tile installer#852
Arimert is offline   Reply With Quote
Unread 11-19-2012, 06:38 PM   #15109
The best part of having the work done all by the same pair of hands; only one person to blame. Plus it saves a huge amount of time as there is no waiting for the plumber to schedule time after framing, then waiting for the electrician... We set the valve bodies ourselves knowing exactly* where the tiles will fall, stuck out the proper depth, pointed in the correct direction, all plumb with each other. That last part seems to be a Herculean task for some round these parts. This particular shower has electronic shower controls and I'm not about to turn something so important over to some Junior plumber who bought his drivers license at the flea market a week ago someone less familiar with high end plumbing.
*as best as one can measure 12 steps ahead of time.
Unread 11-19-2012, 06:54 PM   #15110
Floorit
Tile, Stone and Hardwood
Floorit's Avatar
L.T.
Tile was ceramic, purchased from the big box on the cheap along with the bullnose. So no profiling to be done. Job was done for a GC. I was there long after tile had been purchased and was just a cog in the wheel. Customer is happy, that's all that matters.
Ray
Germantown Tennessee Tile Stone Hardwood Installation
NWFA Member
CTEF Certified Tile Installer
Tennessee Installer of Schluter Kerdi Waterproof Showers
Tennessee Installer of Laticrete Hydroban Waterproof Showers
"Life is pretty simple:you do some stuff. Most fails. Some works. You do more of what works. If it works big, others quickly copy it. Then you do something else. The trick is the doing something else." Leonardo Da Vinci
Floorit is offline   Reply With Quote
Unread 11-19-2012, 07:12 PM   #15111
Kilauea
LT
Kilauea's Avatar
posted by Paul
Valid points.I tell u what,alot of these "licensed" plumbers here in TX arent all they're cracked up to be.There are so many and seems like new companies are always popping up.I tell 'em-dont even set the drain.Just leave me a 2'' pipe stickin out.
*L.T.*
tandctile-dot-net
2nd generation tile installer
Kilauea is offline   Reply With Quote
Unread 11-19-2012, 07:27 PM   #15112
Davestone
Florida Tile & Stone Man
Amos,technically in Fl. if you have a state license in any trade you can subcontract other trades involved in construction.
Most people don't know that.
I took the building inspectors test,but didn't become one when the crash happened.My brotherinlaw is one though,and is also a FEMA inspector.
http://Davestonestile.com
Unread 11-19-2012, 08:32 PM   #15113
Arimert
Arimert's Avatar
ill have to look into that...i have a license to do tile but its only a county license
but it says state license#0000...I had a friend who was called to look at a job
he was a licensed framer,he was asked if he could move a few outlets he said yes,out comes two officers and they arrest him jacked:
Amos
Unread 11-19-2012, 08:44 PM   #15114
pgc555
Alrighty then, I can understand that!
Phil,
http://www.edgestripkits.com/
pgc555 is offline   Reply With Quote
Unread 11-19-2012, 08:54 PM   #15115
Mastic or thin-set -- doesn't much matter. If you let it skin over the tiles won't stick too well.
Unread 11-19-2012, 09:00 PM   #15116
tileman2000
New England Tile Man
tileman2000's Avatar
Or maybe he's going to tile over the drywall.
Another good thing about mastic are the buckets they come in.
Michael
Unread 11-20-2012, 07:59 AM   #15117
jondon
jondon's Avatar
Com'on lets not forget the smell of glue, I mean mastic......
Jon Donmoyer
JD Tile
CTEF Certified Installer #825
Unread 11-20-2012, 08:13 AM   #15118
Sprung831
Tile Tool Guy
Sprung831's Avatar
After this one, my house is all out of bathrooms! lol
Steve Sprung
Technical Manager
Midwest Trade Tool
www.tiletools.com
Sprung831 is offline   Reply With Quote
Unread 11-20-2012, 08:41 AM   #15119
mmmmm, the good ole' stuff
Originally Posted by Sprung831
After this one,
what, you didnt use a leveling system ?
Unread 11-20-2012, 08:43 AM   #15120
pgc555
Hey Obie,
I know a guy that has a tool to help BB those tiles ( post #15088 )
Phil,
Shower Progress Pics Electrician Al Tile Forum/Advice Board 15 07-12-2011 11:38 PM
Noob - questions and (eventually) progress pics hamfist Tile Forum/Advice Board 1 01-29-2011 09:19 AM
Kerdi shower in progress -- 5 pics 4 questions ritch Tile Forum/Advice Board 4 04-20-2009 11:32 PM
Another job finished up (pics) Chris H Tile Forum/Advice Board 10 04-01-2008 06:21 AM
