Unread 12-10-2010, 12:28 PM   #1
Levi the Tile Guy
Tile and Stone Contractor
Levi the Tile Guy's Avatar
transition between tile and wood
Anybody have a pic handy of T molding between tile and hard wood. The hacks on this job before me left a horrible transition between tile and wood floor. It goes from tight to almos 3/8 gap in spots. Cutting it all the tile back to the 3/8 reveal will look real bad, but I can't convince them that a t strip will look better. They r out of tile so popping them up and replacing them isn't an option
Levi The Tile Guy
Unread 12-10-2010, 12:53 PM   #2
Unread 12-10-2010, 12:57 PM   #3
mossypath
mossypath's Avatar
Not very good but found this You can cut a unfinished one down sand and stain to match if it looks to big to them . the 2# pic is of one made .1# pick is a Google search may be you can find more on there
Tammara
mossypath is offline   Reply With Quote
Unread 12-10-2010, 01:15 PM   #4
Unread 12-10-2010, 01:58 PM   #5
madronatile
wood and tile on same plane?
if so a reno-t could work.
http://www.schluter.com/1_3_reno_t.aspx
Matt
www.madronatile.com
Unread 12-16-2010, 04:27 PM   #6
tennesseetile
If its super crooked and want to get the illusion of square I usually cut the bottom part off and drill and hand nail them square to the door casing.
If the gap is close enough I make a sliver on the table saw and glue it in(-1/16-1/4) , but 3/8 is a little big for that. Made some that big for full refinishes in body of hardwood floor.
gram
tennesseetile is offline   Reply With Quote
Unread 12-16-2010, 07:34 PM   #7
Levi the Tile Guy
They opted not to go with a strip in there, so I had to grind in place a straight line (well an equal reveal not necessarily straight) and caulk the entire thing. About 26 linear feet. But they say they are going to replace the 2000' floor and kitchen in phase 2 of the remodel (of a 3 year old, never lived in house) which will be in April.
You guys should see the hack work of the tile guys that were in there before me...wow...hopefully I will remember to take pics tomorrow.
Levi The Tile Guy
Unread 12-16-2010, 08:40 PM   #8
silvercitytile
silvercitytile's Avatar
plz do Levi
Castillo Construction
Unread 12-16-2010, 08:49 PM   #9
T thingee = astragal
Unread 12-16-2010, 11:12 PM   #10
Honeydo
Might not be able to do if you don't have extra wood or can't get a good match but if you have a common finish or extra leftover wood why not either do it or get a decent hardwood guy to cut back the hardwood and picture frame it for a flush transition.
Ed
Honeydo is offline   Reply With Quote
Transition molding between wood and tile? highcountry Tile Forum/Advice Board 3 02-07-2008 05:18 PM
Hard wood to tile transition. tlucas Tile Forum/Advice Board 2 04-04-2006 05:21 PM
Wood to tile transition strip TG Tile Forum/Advice Board 7 06-12-2005 06:58 PM
Transition from Tile to Wood floor mikevdb Tile Forum/Advice Board 3 01-20-2004 11:15 PM
tile/wood transition Tom Tile Forum/Advice Board 6 05-30-2001 04:06 PM
