Unread 06-10-2011, 12:03 PM   #1
rambo1224
Removing Large Porcelain Tiles
I have 18X18 polished porcelin tiles that were put down (on top of ditra) in my entire 1st floor. Unfortunately, the tiiles are not available anymore and I have the need to replace some of the ones that were damaged. What I want to do is remove all the tiles from one room (without breaking them all) and use them as replacements. Once I removed one of the tiles, I was hoping there was some type of tool or blade that I could use to cut thru the thinset.
Once the thinset was cut away from the tile, I could grind the excess off of it and re-use the tile.
Has anybody had any success with a tool or method for getting the tiles up without breaking?
Rob
rambo1224 is offline   Reply With Quote
Unread 06-10-2011, 12:57 PM   #2
Rob, if you set those tiles right, you don't stand much chance of getting any of them up un-broken. Tiles are meant to stay down.
Suction Cups for large Porcelain tiles? Tinman Tile Forum/Advice Board 5 03-28-2008 07:51 AM
Installing Large Format Porcelain Tiles Phildro Tile Forum/Advice Board 27 11-30-2007 08:04 AM
Are large rectified porcelain floor tiles really a job for the pros? Gavin Tile Forum/Advice Board 5 06-07-2005 05:58 AM
Please help w/ removing large tiles on slab MikeShin Tile Forum/Advice Board 2 12-07-2004 12:47 AM
how large is too large for grout between tiles? dee dee Tile Forum/Advice Board 7 06-01-2004 07:36 PM
