Unread 10-14-2006, 08:41 AM   #1
Phildro
Installing Large Format Porcelain Tiles
Hello All-
I'm installing rectified porcelain tiles (13x13) on floor and 12x24 on walls for master bath. I have used Versabond before on ceramic tiles and worked great.
My question is what would be best to use in this situation? The grout lines are going to be 1/32 on floor and 1/16 on walls. The manufacture sugested that i mud in just like marble. That is not an option.
Phil
Phil.
"The breakfast of champions warm beer and cold pizza"
Phildro is offline   Reply With Quote
Unread 10-14-2006, 08:52 AM   #2
koihito
A person, like you.
koihito's Avatar
With those tight joints, I would suggest you look into something like TEC 3N1. Versabond will work, but 3N1 will be much easier to work with.
Nate
www.mikoskiconstruction.com
Unread 10-14-2006, 09:42 AM   #3
Mike2
I'd also go with 3N1 or a full contact (medium bed) mortar like Mapei's Ultracontact. Have used and would recommend both.
I'd get the walls flat first before laying the 24's. Can almost guarantee that if they have been taped with mud they will need some work, especially the inside and outside corners that flare out. I'd also consider seven-spotting the wall tiles (seven dollips of mortar on the back in lieu of a full spread. And while you're at it, get that floor flat too. I'd shoot for 1/8" over 10 feet with rectified and a 1/16".
Unread 10-14-2006, 08:44 PM   #4
Phildro
Thanks guys for the fast replies, the TEC is not readily available. I went with Customs marble and granite. Good stuff?
Yes the walls and floor are flat, i have spent many a long night getting that done
Thanks again for the help.
Phil.
Unread 10-15-2006, 09:51 AM   #5
Phil,
I shoot for more like 3/32 to 1/8 with rectified tiles. Two-dimensional size is usually pretty good, but "cupping" is still a problem, and this causes the side of one tile to be higher than the other. Spreading them just a bit helps there.
Custom's Marble and Granite is a good product.
Unread 11-27-2007, 09:45 PM   #6
Phildro
hello to all- it's been awhile but the tile is up and I'm getting ready to grout. Does anyone know where i can buy Latisil on-line? I can't find it local.
Phil.
Unread 11-27-2007, 11:05 PM   #7
Phildro
I know the board likes pictures So I would like to share my progress with you. I used Custom's Granite and Marble thin-set,back-buttered every one. Tile's set 1/32 this was a royal PITA.
My hat off to you guy's who do this everyday. I hope to have the completed pic's soon.
Phil.
Unread 11-27-2007, 11:09 PM   #8
Phildro
started to rip out old mold greenboard
Phil.
Unread 11-27-2007, 11:11 PM   #9
Phildro
Phil.
Unread 11-27-2007, 11:20 PM   #10
Phildro
this was all black mold, the greenboard was dripping with water, floor of shower was sloped to wall-not drain
Phil.
Unread 11-27-2007, 11:22 PM   #11
Phildro
moved drain and new p-trap
Phil.
Unread 11-27-2007, 11:29 PM   #12
Phildro
new plumbing
Phil.
Unread 11-27-2007, 11:32 PM   #13
Phildro
new wall
Phil.
Unread 11-27-2007, 11:34 PM   #14
Phildro
main floor
Phil.
Unread 11-27-2007, 11:37 PM   #15
Phildro
Kerdi
Phil.
