Unread 06-19-2021, 03:23 PM   #1
A440
How to transition an outside corner between tile and drywall
Hi,
First time poster.
I am using kerdi-board and tile in the shower. One of the walls will come out past the glass doors and meet drywall at an outside corner. What materials should I use? Do I use an outside corner bead and/or a Schluter edge? Thinset or drywall mud at the corner?
Thanks for your help.
Tim
A440 is online now   Reply With Quote
Unread 06-19-2021, 04:13 PM   #2
Many times we use a row of matching bullnose if there's one available. If not you can use a Schluter profile edge. Sometimes I use a double row of bullnose, one at the corner and another extending around the corner. I would make sure the corner is straight and plumb.
Unread 06-19-2021, 09:59 PM   #3
If you're not wrapping the tile around the corner, you should use a drywall corner bead there.
Unread 07-05-2021, 02:50 PM   #4
A440
What size spacers for 4x10 subway tile?
What is the recommended spacer size for a shower using 4x10 subway tile?
Tim
Unread 07-05-2021, 03:03 PM   #5
Hi Tim. There are no rules but I use 1/8 wedges more than anything.
Unread 07-05-2021, 03:28 PM   #6
Welcome, Tim.
It'll help if you'll keep all your project questions on one thread so folks can see what you're working on and what's been previously asked and answered. A moderator can give it a more generic title any time you'd like to suggest one.
The ceramic tile industry calls for a minimum grout joint to be three times the difference in size between the largest and smallest tile of the same nominal size in your layout, Tim. Aside from that it's an aesthetic consideration.
Unread 07-05-2021, 04:13 PM   #7
A440
Will do.
Tim
Unread 07-07-2021, 11:13 AM   #8
A440
Remove shower drain from fiberglass base
I'm removing a Sterling fiberglass 3-piece wall surround with fiberglass base. The drain will need to be removed from the top. If I can't get the old drain out by unscrewing it, should I use an inside pipe cutter to remove it before I install the Schluter flange?
Tim
Unread 07-07-2021, 12:11 PM   #9
That's a possible option, Tim, but we don't know enough about what you have to give you a definite answer.
Unread 07-11-2021, 01:32 PM   #10
A440
Depth of Moen Posi-Temp Plaster Ground
Another quick question for the group.
When installing a Moen Posi-Temp Valve with the plastic Plaster Ground, should my goal be to have the outside (larger circle) of the plaster guard flush with the finished tile wall? I plan to use a scrap piece of 3/4" plywood to simulate the depth of the 1/2" Kerdi Board, thinset and 3/8" subway tile. Or should I recess it just a bit behind where the finished wall will be?
Tim
Unread 07-11-2021, 02:28 PM   #11
There should be instructions with that water control valve telling you the proper installation position. In my experience it does generally want to have the plaster guard flush with the finished wall surface. But you want to check the instructions for your particular unit.
Not sure just how your simulation would work. Your plywood, at a max of 23/32nds" thick is gonna be substantially thinner than just your wallboard and tile thickness of 7/8ths" without any bonding mortar.
Unread 07-11-2021, 03:45 PM   #12
When in doubt, get the trim out and fasten it to the valve to see what it needs to be. Usually there is a maximum and minimum with some wiggle room.
Unread 07-11-2021, 05:44 PM   #13
A440
Will do. Good idea, thanks!
Tim
Unread 07-12-2021, 09:53 AM   #14
A440
Drain removal question
OK, so we got the drain unscrewed from the shower pan and the pan removed. Now there is a section that remains with a collar (of sorts) along with an piece of ABS that leads to the trap. We are not sure if this can be unscrewed or needs to be cut. Any of the pros here willing to give us a heads up before I take the photos to the plumbing supply store?
Tim
Unread 07-12-2021, 12:09 PM   #15
Matters not, Tim. Either way you'll need to cut the riser pipe (vertical piece from trap to drain) to length in order to glue on your new drain.
Tile to drywall corner transition question jasondiy112 Tile Forum/Advice Board 11 04-18-2019 02:35 PM
How to deal with backer board/drywall transition at inside corner ryebotanist Tile Forum/Advice Board 16 10-07-2015 08:53 AM
How to tile/trim outside corner transition cruisin_n_style Tile Forum/Advice Board 13 11-24-2014 06:10 PM
corner bead for drywall/cement board corner FJK Tile Forum/Advice Board 11 07-10-2011 01:33 PM
Outside corner Paint/Tile transition walktall Tile Forum/Advice Board 3 11-27-2004 08:22 PM
