Unread 06-13-2021, 11:05 AM   #1
tscoffey
How to tile around immovable kitchen island
I am going to be tiling my kitchen fairly soon with 3/8 floor tile. The floor currently has 3/4 hardwood on it, which will be removed.There is also an island that has a 350 pound piece of granite on it. The island cabinets were set over the hardwood, but I can’t risk moving it temporarily to remove that flooring because of the risk of breaking the granite.
So I have to somehow remove the flooring as close as possible to the perimeter of the cabinets. I can do that, but it seems that the finished mortar+tile height will be slight lower than the finished hardwood height.
How do I treat that height difference? Some kind of edge treatment (tile, wood trim) around the island cabinets?
Tim
tscoffey is offline   Reply With Quote
Unread 06-13-2021, 11:18 AM   #2
Hi Tim, shoe mould is sometimes used. It's 3/4 inch tall and 1/2 inch wide.
Unread 06-13-2021, 12:53 PM   #3
Hi Tim,
I go along with Davy. I think you'll have to cut the flooring flush with the cabinet side. Use either a multi-tool with saw attachment or a toe space saw. The toe space saw is a little risky to use, though.
Unread 06-13-2021, 01:08 PM   #4
Is this going over concrete or wood subfloor? If it's a wood subfloor, you should figure in the height of a tile backer.
Unread 06-13-2021, 01:39 PM   #5
tscoffey
KMan - Good catch. Yes, 1/4 tile backer over the subfloor. That brings the finished tile height just over the hardwood. Similar problem, but I think the shoe mould solves that rather easily. And I just *might* be able to get a small circular saw within 3/4 inch of those cabinets. I have a multitool saw, but it just takes so long to get thru hardwood with it.
Tim
Unread 06-13-2021, 02:17 PM   #6
If you’re not familiar with a toe kick saw, they are a small circular saw with a very off-set blade that is meant to cut exactly what you need to cut. But the off-set blade unfortunately permits you to twist the saw a bit and cause it to kick back. If you’re going to use this tool, it’s worth practicing on scrap a bit. They are available at some tool rental places.
new kitchen - heavy island bluetempo Tile Forum/Advice Board 3 11-26-2019 07:26 PM
Ceramic tile on the walls of kitchen island flfiregirl Tile Forum/Advice Board 0 09-22-2011 01:46 PM
Electric to New Kitchen Island LLBradford Tile Forum/Advice Board 1 09-09-2009 05:34 PM
BBQ Island / Outdoor Kitchen gasgrill Tile Forum/Advice Board 12 05-01-2009 07:46 AM
Immovable 60's ceramic tile over morter wall Mummy Tile Forum/Advice Board 10 07-07-2006 07:23 PM
