Unread 06-12-2021, 02:32 PM   #1
Uvawkidd
Curb Slope
Thanks for any advise.
I’ve attached a couple pictures, one showing the slope out to in on a torpedo level and another showing right to left on the curb.
Seems to me that the water should drain faster, is this enough slope?
Thank you
Jon
Uvawkidd is offline   Reply With Quote
Unread 06-12-2021, 03:03 PM   #2
From left to right, it should be level. The pitch should be at least 1/8 inch, I usually shoot for 3/16. You probably have a little less than 1/8 if I had to guess.
Unread 06-12-2021, 05:25 PM   #3
Uvawkidd
Less than 1/16
Thanks Davy.
It is sloped right to left, about a half an inch lower on left across 50 inch curb.
I did some playing with the level and it’s less than 1/16, right at 1/16 at best on the slope.
Not good huh?
Thanks again
Jon
Unread 06-12-2021, 06:52 PM   #4
Surface tension will usually keep it all from running off and yours will run off slower than it should. I don't know if it's worth fixing.
Is this a tile curb?
Is it a new installation? If so, you might talk to the installer.
Unread 06-17-2021, 02:16 PM   #5
Uvawkidd
Quartz
There curb is quartz, one piece.
Jon
Unread 06-17-2021, 03:02 PM   #6
Lazarus
Lazarus's Avatar
Yeah.....should have been adjusted while it was being installed....just a tad more than what you have.
Laz
If you think hiring a professional is expensive, wait until you see the cost of hiring a amateur.
Unread 06-17-2021, 08:50 PM   #7
Depending on how it was installed, I might consider removal and replacement with a bit more slope.
If it's otherwise installed properly and the waterproofing layer might be compromised during removal, I'd probably just wipe it down with a towel after each use.
Slope and curb worries Furious82 Tile Forum/Advice Board 101 02-02-2017 08:46 PM
Curb with no slope Eurf Tile Forum/Advice Board 20 03-20-2006 09:08 PM
Curb Slope G.Wills Tile Forum/Advice Board 4 03-09-2004 08:07 PM
Curb Slope - How? dwzemens Tile Forum/Advice Board 8 01-31-2004 06:29 PM
curb slope sounder_4 Tile Forum/Advice Board 7 07-27-2003 01:38 PM
