Unread 12-20-2003, 09:24 PM   #16
Well, I knew zackly what you meant when you said 90 degrees, whether it was meaningful or not.
And yes, that rake would be negative. I can't testify that it's 5 degrees, but it's in that vicinity.
John, I'm a little surprised at you. You'd begrudge the boy an opportunity to buy a new tool? Not like you a-tall, seems like.
So, what would a fella cut his geodes with, then, if not with a wet saw?
Unread 03-21-2008, 12:58 PM   #17
Cdirect143
Jesse
Cdirect143's Avatar
Metal Cutting Blade
Alpha makes a special metal tile cutting blade called Metalgres. Contractors direct has it for $121.99 for a 10". Item PM10A
Cdirect143 is offline   Reply With Quote
Unread 03-21-2008, 10:23 PM   #18
CrazyHorse
Aaron
A band saw is the best tool to cut metal tiles. It is what we use for suspended computer floors which are 2'x2' metal tiles, some are even filled with a type of cement. A large band saw has no problem with them but a small one would do for you.
CrazyHorse is offline   Reply With Quote
Unread 03-21-2008, 10:46 PM   #19
Thread's four years old, guys.
Dredging up four-year-old threads for the purpose of promoting your company's products might be considered spamming in some circles, Jesse.
