Unread 09-13-2007, 08:37 PM   #16
ragdoll
I have to share.
This comes with perfect timing with this active thread...
I got my toilet back in to the bathroom and got everything set, straight, screwed and a little shimmed(with one nickel and one dime). Did I test sit on it... seemed solid until I leaned forward. The whole thing picked up as if the bolts on the floor weren't even there! I COMPLETELY forgot to bolt the flange to the floor. Ha. I guess I get to start over now... Weeeee.
Yeah... BOLT/SCREW IT DOWN.
-Chad
ragdoll is offline   Reply With Quote
Unread 09-13-2007, 08:56 PM   #17
ckl111
Home Builder
Thanks for sharing.
Also don't forget to remove the rag that you used to plug the pipe with during construction. Guess how I know....
Colin
ckl111 is offline   Reply With Quote
Unread 09-14-2007, 05:32 AM   #18
TedL
Mary Ann: One final tip - get a "plain" wax ring to set the toilet with. No plastic inserts, which can serve as a bottleneck.
Colin: There are saws sold that go into a drill and cut the pipe from the inside. About $10 at the big boxes or almost any place that sells plumbing supplies.
This link just for a pic of the idea:
http://www.plumbersurplus.com/Prod/D.../59622/Cat/704
Ted
TedL is offline   Reply With Quote
Unread 09-14-2007, 05:40 AM   #19
opiethetileman
opiethetileman's Avatar
in my long time of remodeling i do belive i have only seen 10 to 15 flanges screwed to the floor. Only thoose were wood sub floors. I have never yet seen a flange screwed to concrete
opiethetileman is offline   Reply With Quote
Unread 09-14-2007, 05:55 AM   #20
TedL
If this were limited to concrete, I would understand that there's at least an argument to be made.
Not screwing the flange to a wood subfloor is just lazy, sloppy work with a "screw the customer" attitude (no pun intended).
There's a lot of showers with tile on greenboard with mastic too. Doesn't make it right.
Ted
Unread 09-14-2007, 07:42 AM   #21
ckl111
Home Builder
Thanks for the info Ted,
I've never seen one at the local big box but now I know what to look for.
No more melting it with the ol' angle grinder.
Colin
Unread 09-14-2007, 09:20 AM   #22
BlueCanyon
You guys are a wealth of information.
We have one of those inside pipe cutters - had to get it for the pipe coming out of the shower floor. We got it at HD for about 12$, and it worked great.
Remove rag stuffed into pipe. Got it.
Mary Ann
BlueCanyon is offline   Reply With Quote
Unread 09-14-2007, 12:16 PM   #23
jdm
jdm's Avatar
If you have a Dremel tool or a Rotozip with the long flexible attachment, then all you need is a cutoff wheel to use it for making inside pipe cuts.
MaryAnn, I know that you said that you already have the tool, but around here, I get the feeling that the wall have eyes.
jeff
Go Rutgers!
Unread 09-14-2007, 04:51 PM   #24
TedL
A Dremel or like tool would certainly work.
I use a fiberglass reinforced cutoff wheel for about 90% of the cutting I do with my rotary tool, but for wood or plastic, they are not my choice. A (saw) blade with teeth would be.
Ted
