Unread 04-02-2020, 09:43 AM   #1
dianna
Tile leveling systems -anything new and improved?
Hi guys, the latest post I saw about leveling systems was from over a year ago. Is there anything new and improved for the DIY-er? From what I saw in previous posts, Raimondi Leveling System was the most recommended. I've been having decent results using a hockey puck, but it takes me forever and am often pulling tiles out and redoing them. I'd rather spend the money on a leveling system!
Dianna
dianna is offline   Reply With Quote
Unread 04-02-2020, 09:52 AM   #2
Just a DIY'er, Dianna, and the only one I've used is Spin Doctor. Very easy to use, I had great results with it, but it's a bit spendy to start up. But once the caps and anti-friction clear disks are bought they get used again and again, so you're only buying the spacers after that. No special tools required.
Unread 04-02-2020, 10:05 AM   #3
pls
I also like the spin doctor. My Lowes no longer carries them so I have to order online.
Phil
pls is offline   Reply With Quote
Unread 04-02-2020, 10:05 AM   #4
Welcome back, Dianna.
You are aware that none of the "leveling" systems do any leveling at all, yes? They are more accurately described as lippage control systems. You might still find yourself needing to do much the same "adjustment" as you do without the mechanical system, but the mechanical systems do hold the tile edges in place more securely than without them.
If you are a person who can set lippage-free tile installations without the lippage control devices, they're certainly helpful, but are likely to slow your speed a bit, at least at first.
One of the most versatile systems, and the only one with which I have any experience, is the MLT System. Not gonna be the least expensive up front, but may be what you want for the longer term if you expect to be setting a lot of tile. One of the tool-les systems might be better if you're not planning a lot of need.
Unread 04-02-2020, 02:02 PM   #5
dianna
Thank you for the responses! I am aware that these prevent lippage. I am really good at getting my floor tiles lippage-free, but wall tiles seem to be more of a challenge for me. The hockey puck works pretty well, but when I see videos of people tiling with the systems, it looks so easy! But then again, everything a pro does looks easy compared to my skills! I am actually finishing a project I started a long time ago, embarrassingly. I plan to post up some pics when I finish up the shower in the bathroom. My next pandemic project is another bathroom. I appreciate all of the help!
Dianna
MLT Systems (Tile Leveling System) ceramictec Professionals' Hangout 1619 01-20-2019 06:37 PM
Tile Leveling Systems - Help app1fjc Tile Forum/Advice Board 4 03-29-2017 11:09 AM
Tile leveling systems kaudley Tile Forum/Advice Board 6 02-10-2017 04:43 PM
Tile leveling systems for homeowner uconncraig Tile Forum/Advice Board 27 09-09-2015 09:30 AM
Tile Leveling Systems Plumbline Tile Forum/Advice Board 8 12-21-2011 09:35 AM
