Unread 01-11-2020, 12:24 PM   #1
Lou_MA
How long to wait - washing machine and new tile floor
12” x 24” porcelain, set with modified over Hydroban, over slab. Any thoughts how long to wait before front load washing machine and dryer can be moved back on it and put back in service?
Lou
Unread 01-11-2020, 01:22 PM   #2
Lazarus
Lazarus's Avatar
Probably safe with 24 hours, but I'd give it 48 just for insurance.....
Laz...
Unread 01-11-2020, 08:22 PM   #3
My front loader weighs nearly 250#, and the diameter of the feet is pretty small. Then, when it runs, if the load is somewhat unbalanced, it can shake a bit (a lot of the weight is to help keep it in place to offset the unbalanced load).
A lot of the strength happens in the first couple of days, but industry still says the strength is at 28-days. Personally, to be sure, especially since you may be moving things in there on a dolly, where the weight is even more concentrated, I'd wait a bit longer. If you happen to run over an edge that didn't get 100% coverage, you'll probably know it!
Unread 01-11-2020, 08:43 PM   #4
workhurts
This is a trick question. Throw out the front loader
Charlie
Unread 01-11-2020, 09:01 PM   #5
Have you ever seen a top loader walk across the room?
Unread 01-11-2020, 10:17 PM   #6
Laz is a lot more gutsy than I for a front load washer to be in use a mere 48 hours after setting.
My answer would be: “That depends; what mortar?” The answer to that may or may not give me enough info, as I know some mortars better than others.
Unread 01-11-2020, 10:26 PM   #7
Modified thinset directly to the slab would set faster and 48 hours might be long enough. Not sure if 48 is enough with modified thinset between Hydroban and porcelain.
Unread 01-11-2020, 11:09 PM   #8
Lou_MA
Thanks guys. I misspoke, it’s a top load washer, not front load. Don’t know if that makes a difference
Bubba - Thinset is Laticrete tri-lite.
Davy and Jim - what amount of time would you be comfortable with if it was your house?
Lou
Unread 01-11-2020, 11:36 PM   #9
Depending on the thinset used, a couple of days might be enough, but if I could, I'd wait a week. If I moved it sooner, I'd lay down a sheet of ply so the load would be spread getting it there. It might also depend on when I wanted to run my first load.
Make sure to level the feet well so it doesn't rock.
Unread 01-12-2020, 07:12 AM   #10
Front or top load, I'd wait 48, but I'd wait a week before use. The filled weight is one thing, but the vibrations are another.
Unread 01-12-2020, 04:17 PM   #11
Dave Gobis
da Man!
Dave Gobis's Avatar
My opinion would be a week.
Floor Drain Beneath Washing Machine Trollslayer Tile Forum/Advice Board 13 04-10-2014 07:20 AM
Washing Machine Isolation Slab rszevery Tile Forum/Advice Board 6 08-06-2013 07:41 AM
Laundry Room (2nd floor) ~ Washing Machine Pan and Drain? MommyZero Tile Forum/Advice Board 8 09-14-2010 02:15 PM
Advice: Ditra under washing machine... in2explore Tile Forum/Advice Board 16 11-04-2006 07:20 AM
Floor Drain or plastic drain pan for washing machine rmcneil Tile Forum/Advice Board 20 09-11-2005 07:11 PM
