Unread 12-13-2019, 10:35 AM   #1
tstex
sealing outdoor slate on balcony
Hello and Merry CHRISTmas to all.
I have an outdoor balcony w rough slate that is not covered and faces the east. It needs to be sealed. I have cleaned it 2-3 times and rinsed. That was last week. It rained this tuesday, but I completely covered it up, then removed the plastic and it's ready to go...perfect weather to seal.
It has a few places where the grout is stained. When we had heavy past rains, the water penetrates the grout via small hairlike cracks to the subflooring and comes out the sides into the gutter from between the slate and subflooring. Nothing has ever penetrated the subflooring and leaked thru to the white ceiling below. I am using Aqua Mix Enrich"N"Seal.
Questions: Will the sealer penetrate the small cracks in grout to prevent seepage to the subfloor? If not, do you have a recommendation?
Next, what is the best thing for cleaning some of grout?
Finally, what is preferred or best method to apply the sealer/enhancer for outdoor rough slate?
Thank you very much,
tstex
Tom
tstex is offline   Reply With Quote
Unread 12-13-2019, 10:38 AM   #2
tstex
If you need some pic's, pls let me know?
Thanks in advance !
Tom
Unread 12-13-2019, 06:22 PM   #3
And a Merry CHRISTmas to you, too, Tom!
Pictures are good.
With this being outside, any idea what is causing the staining?
The term sealer is very misleading. It should be called “temporary stain blocker while you quick clean it up”. It does not stop moisture. Especially in physical cracks. But realize that the waterproofing should have been done before a single piece of stone was installed. It’s the subsurface waterproofing that keeps the moisture from penetrating into the structure. Do you have any idea of how the waterproofing was done? We might be able to see something with a few pics.
Unread 12-14-2019, 01:46 PM   #4
tstex
thank you very much Tool-Guy.
Will get some pics to you soon...I believe that w sun, humidity, rain and airborne materials, over time, it has taken its toll on this area. The grout probably just got dirt in it over time. It's my mistake for not getting to this area earlier.
Not sure what the subsurface is made of or how constructed, but nothing has ever leaked into the ceiling or structure. The ceiling is white so I would see if anything penetrated or stained it.'
Thanks again and I will be in contact very soon,
Tom
Tom
Cleaning and Sealing Outdoor Slate Gardenmom Cleaning, Restoration and Sealing 2 09-07-2015 11:30 AM
Funky Balcony outdoor tile.... Randyj Tile Forum/Advice Board 4 01-02-2012 12:09 PM
Tile Outdoor Balcony w Metal Pan Meyco Tile Forum/Advice Board 17 01-02-2012 12:05 PM
How long to wait before acid cleaning and sealing outdoor slate? RT27 Cleaning, Restoration and Sealing 1 08-31-2008 09:39 PM
Outdoor Balcony - Ditra? ssailer Professionals' Hangout 10 09-04-2007 08:44 PM
