Unread 01-25-2019, 01:24 PM   #1
lothian
Advice: Miniscule Lippage Removal
I made square surround using 12" travertine crown end-butted (no grout). Of the 14 joints (4 of which are 45° miters) I managed to get 10 perfect; meaning perfectly aligned. The balance have a hairs' width lippage which bothers me on a neural level. But it seems it couldn't be avoided, attributed to my skill level with this art.
Lippage is so minimal that I imagine grinding it away using a honing stone of some sort. I own a whetstone for sharping knives, but this seems inelegant.
Rather than ugly-up my otherwise not-half-bad work, I need advice.
Suggestions? Recommendations?
Lot
lothian is offline   Reply With Quote
Unread 01-25-2019, 02:53 PM   #2
JoeBoxer
Slow Poke
Travertine is a softer stone, so many options to smooth it down and polish it back. Go nuts.
JoeBoxer is offline   Reply With Quote
Unread 01-25-2019, 03:11 PM   #3
mark999
butting tiles together with no grout joint is a no no .
Mark
Unread 01-25-2019, 08:29 PM   #4
workhurts
What's a square surround?
Charlie
Unread 03-29-2020, 10:04 AM   #5
lothian
"square surround"...
akin to 'Some folks call it a sling blade, I call it a kaiser blade.'
examples of no lippage vs. lippage...
Lot
Unread 03-29-2020, 10:54 AM   #6
jerrymlr1
Like you said, miniscule. I would grout it and move on. I'm pretty detail oriented too.
Jerry
Unread 03-29-2020, 06:57 PM   #7
I'm afraid if you start going over it with a whetstone, you'll have a lot of scratches in it that would be hard to remove. I would practice on a scrap piece first.
But, I'm with Jerry. You likely have just as much lippage in the field tiles surrounding the square. I'd grout it and move on.
Unread 03-30-2020, 06:08 PM   #8
Karls tile Inc
Tile and stone contractor Tile setter
Those travertine chair rails are rarely perfect.The profiles will vary from piece to piece. Most times when we install them we will put a grout joint to hide the imperfections.
Karl
Karlstile.com
Karls tile Inc is offline   Reply With Quote
Unread 03-30-2020, 09:05 PM   #9
I also like beating the details to perfection. But I agree with the others that it’s better to leave that alone rather than grinding it.
Quick question: is that a backsplash behind something like a wet bar...or behind a stove?
another marble mosaic lippage problem-advice needed zanne_lh Tile Forum/Advice Board 17 03-13-2014 08:14 PM
Problem with lippage removal and restoring the factory finish on a granite floor dalandis Cleaning, Restoration and Sealing 18 03-03-2013 05:59 PM
Advice needed on lippage Dugald Tile Forum/Advice Board 13 04-27-2010 02:04 PM
old mastic removal advice tony d Tile Forum/Advice Board 5 03-10-2007 10:36 AM
Barb's Miniscule Bathroom derpbag Tile Forum/Advice Board 32 11-30-2006 11:16 AM
