Unread 12-12-2018, 06:47 PM   #61
Raymond S
Carpenter - Tile Setter
Second on the putty knife and pry bar, but I never mind looking at new tools or new methods. Thanks.
Raymond
Raymond S is offline   Reply With Quote
Unread 12-17-2018, 08:59 AM   #62
Simplyjames
Simplyjames's Avatar
Whose got a hack for making tiling easier...
Just decided it’s 12% faster to keep tile wedges in the rinse bucket. They float on top so they’re easier to pick up than when in a pouch or box. Also saves time because you’re grabbing the sponge anyhow for every tile.
James
ACT certified installer #015
californiaflooringltd.com
Simplyjames is offline   Reply With Quote
Unread 12-17-2018, 07:20 PM   #63
Just In Tile LLC
Just In Tile LLC's Avatar
Probably cuts down on the spillage of the wedges too James
Justin
Just In Tile LLC is online now   Reply With Quote
Unread 01-09-2019, 03:25 PM   #64
jroush
64th inch joints please
jroush's Avatar
Sponge Hack
Maybe this is common practice but I discovered how to clean a grout sponge by tapping it on flat surface when its dry. All the sand building up in the sponge comes out. Totally refreshes the sponge.
J.R.
jroush is offline   Reply With Quote
Unread 01-09-2019, 06:28 PM   #65
Just In Tile LLC
I like it J.R. speaking of sponge tricks, I use mine to fill up the saw tray by sticking it in the tray and full blasting the nozzle into it, no splashing.
Justin
Unread 01-14-2019, 08:54 AM   #66
Just In Tile LLC
Like this
Justin
Unread 05-07-2019, 01:07 PM   #67
smifwal
I like to measure and mark my usable scape pieces of shower membrane. I use to just roll then up and stick them in a tube, then when I would pull them out and oh that one looks big enough and it be a inch short or some weird shaped triangle.
Unread 05-10-2019, 10:57 AM   #68
Tiger Mountain Tile Inc
I do the same thing. With membranes, I will often write how much I've used so far so I have an idea of what's left.
Jim Upton
Curious how the new Delta Cruzer tile saw stacks up against Dewalt? Check out the full review and video on DIYTileGuy
Unread 06-13-2019, 06:57 PM   #69
smifwal
this house set up was so old school. Back deck 14 stairs, front deck 12, in through the garage 6 a landing and 7 more and once you were in the house, the master was the furthest away from any entrance so I definitely wasn't hauling water through the house and when it came time to flood I just grabbed some plumbing and ran it off the toilet line I had been getting water through out the job
Unread 06-13-2019, 08:33 PM   #70
CaliGrown
CaliGrown's Avatar
That’s the way to do it, right on Shawn. Bet those walls went up quick!
Christopher Machado 1 (916) 990-1751
Rest In Peace Joey Peres (7/16/95 - 8/31/19).
“When you bid it to get it, don’t be mad with what you get.”
Unread 06-29-2019, 06:50 PM   #71
thuffner3
A few scratch cutter tricks,
I have several Rubi cutters, Love my Rubi's.
1 Sigma
1 Tomacanic
several little Superior cutters.
Rubi's, Have you figured out what the scale on the far side of the measurement bar is? It is 1.41" longer than an 1" for 45 degree layout, measured from the wall to the vertices of two intersecting tiles you would use the far scale for this.
Left your tape on the shower bench after you walked downstairs to make your list of cuts, no problem. Rubi's have a 12" bar on the left and a 16" bar on the right. 28". You do the math.
Having trouble seeing scales obscured by cutter rails, add or subtract a whole number from your measurement and align the subtracted number to the corresponding number on the scale.
More to come;
Neil Jackson, from Cincinnati, Ohio
Her contractor said she could have it installed today.
thuffner3 is offline   Reply With Quote
Unread 07-23-2019, 05:16 PM   #72
CaliGrown
CaliGrown's Avatar
Any tricks?
Anyone know remedies for cement burn? The hawk was rubbing on me as the day got later. A long sleeve would be a fine idea if it wasn’t summertime in CA.
Unread 07-23-2019, 06:20 PM   #73
jerrymlr1
If it were me, but it aint, I would wash it with a muriatic acid solution, rinse it, and put some neosporin on it. Might sting a bit but only till you rinse it. Need to get that portland out.
Unread 07-23-2019, 07:27 PM   #74
smifwal
wash it with vinegar and water, pat it dry and put some aloe vera on it
Unread 07-23-2019, 07:39 PM   #75
CaliGrown
CaliGrown's Avatar
Right on!!! You guys are smart. Thank you, if only I could stop getting strawberries on my finger tips when doing veneer. At least those are my only problems, until I upgrade knee replacements when I get to 60 or so
making and tiling a half column bender123 Tile Forum/Advice Board 9 06-10-2010 09:52 AM
Another Hack Job HS345 Professionals' Hangout 35 02-24-2009 10:26 PM
An easier way! mmoore Tile Forum/Advice Board 22 12-11-2008 09:07 AM
What a hack job. muley Professionals' Hangout 13 03-07-2007 01:06 PM
Hack job Northwest Tile Guy Professionals' Hangout 19 12-09-2006 06:57 PM
