Unread 10-01-2013, 01:20 PM   #1
snrusnak
Which method do you prefer?
After seeing a bunch of you "regulars" that are pros comment and follow my thread, I'm just curious which methods you would choose to build a shower. "conventional", kerdi, etc?
I had never even heard of kerdi and the others until I logged on to this forum. I thought the method I was using was basically the only way.
I don't intend to use another method anytime soon, just curious which you all prefer. The others seem to be preferred around here, although I've seen a couple negative posts about them lately.
Sean
snrusnak is offline   Reply With Quote
Unread 10-01-2013, 02:14 PM   #2
MDtile
I'll play . I'm sure this will get moved to the pro's hangout.
I prefer "conventional". That would be mud on lath, as was done for centuries and still is by some of us. Setting tile on a nice flat, level, plumb mud bed is the absolute Cadillac ride of our trade. Also the fastest way to get from point A to point B, and will withstand the test of time ( when done RIGHT, but that's true for ANY METHOD), which only time will tell with any of the new school methods. I have heard that there is tile work at the Roman Coliseum that looks like it was done a few years ago with grout work that few people could match today. And I was told that by a tile man ( I've never been there ).
MDtile is offline   Reply With Quote
Unread 10-01-2013, 08:19 PM   #3
Im with Marty, I like the flatness and longevity of mud work. I also agree that any of the installations methods will last if done correctly. That seems to be the biggest problem we see, installations done incorrectly.
Unread 10-01-2013, 08:30 PM   #4
ob1kanobee
ob1kanobee's Avatar
Yeah but can you do a conventional mud shower for a curbless shower say on the 8th floor in a condominium with a linear drain?
Ben
Unread 10-01-2013, 10:01 PM   #5
PetrH
There are different methods for different budgets, some people want a mercedes, others a ford. Most of the showers I do are: Den's Shield on the walls, with liquid applied waterproofing and glass fabric in all corners and at fasteners. kerdi in the shower pan and 2" up the walls. It's not the absolute best way a shower can be done, but it's economical and I have no worries putting a 30 year warranty on it.
Petr
Unread 10-01-2013, 10:12 PM   #6
Deckert
Seems like this topic always gets presented like mud and "new fangled fancy pants" waterproofing and drains are mutually exclusive. Why not mud and a surface applied waterproofing and any type of curb you want, and any style of drain you like?
Brannigan
HeenanGC.com
Unread 10-02-2013, 12:40 AM   #7
Higher Standard Tile
Tile and Stone Contractor
Higher Standard Tile's Avatar
I agree with Brannigan. They can work together. Plenty of guys mud walls and apply Kerdi or Liquid Membranes on the surface.
Learn everything, then use what works best for your particular job/application and do it correctly.
Then don't assume that everybody that makes a educated decision to use a different approved method is a hack.
Not saying anybody on this thread is implying that but I see too often that once a person is comfortable with a particular method they assume anybody that chooses a different method is making a bad decision.
Isaac
Higher Standard Tile & Stone
Maui, Hawaii
Unread 10-02-2013, 11:35 AM   #8
MDtile
I'm down with everybody's preferred methods being just that: preferred. As long as none us decide to "read between the lines" or decide that something is implied that isn't written, should be no problems
We can all voice our "whys" without stepping into the territory of being directly on top of someone else's foot if we watch our words. There are more than 2 camps methinks....
Unread 10-02-2013, 11:53 AM   #9
MDtile
Absolutely Ben, if they will just issue that variance on the 2" from finished floor to drain top. I would probably preclude a PVC pan liner however. There are plenty of different ways to WP a shower pan besides the stuff we talk about here all the time. Some new technology being offered by waterproofing specialists. Did one in Los Altos Hills in a sub-grade concrete tank using a custom-made channel drain that had no flanges for a surface WP like Kerdi or paint-on, and was set-up to attach directly to a glue-to-threaded pipe fitting so no flange drain either. The guy that WPed it used some type of space age sealant and felt. The stuff stunk like no tomorrow, and that was still nauseating the next several days to boot. We hydrobaned our deck mud final slope and drilled a few holes into the SS channel right at the deck mud just in case. That's what the general contractor wanted to do, because I insisted that I wasn't doing a pan liner with no drain flange no way, so lose the custom-made channel. It's his house to warranty, and he's a big boy. He won't involve me in any possible future problems, and never goes back on a verbal. The kind of contractor we likes
Unread 10-02-2013, 07:49 PM   #10
Dan Kramer
Registered Tile/Stone User
Dan Kramer's Avatar
I have not learned mud. Missed the class. Used to do c.b.u., pre-sloped pans and mud curbs. 6 years ago I stumbled through a kerdi shower. Never went back. I use some liquids but mainly kerdi board and kerdi. No comparison for me.
Dan Kramer is offline   Reply With Quote
Unread 10-02-2013, 07:54 PM   #11
Dan Kramer
Dan Kramer's Avatar
I should add in the few short years before I joined the forum and while working as a helper, we didn't use a pre-slope and nailed backerboard to the curb. Doh. Dint no no bettah
Unread 10-03-2013, 05:47 AM   #12
Eschbach
Tile Contractor-Virginia
I use Kerdi board,Kerdi and a Kerdi drain.I keep the trailer stocked with these items and the accessories.
I sell the Kerdi shower system and some people ask for it by name.Orange is everywhere.
www.eschbachrenovations.com
Virginia Installer of Schluter Kerdi and Kerdi Board Waterproof Showers
Excellence is no accident
Eschbach is offline   Reply With Quote
Kerdi Mortar -- Prefer Modified or Unmodified? quinocampa Tile Forum/Advice Board 3 08-12-2009 09:51 PM
Why do some pros prefer plain thinset (no latex)? JaserLet Tile Forum/Advice Board 6 10-09-2006 10:47 AM
How would prof. tile setters prefer to install mosaics and inserts? Katherine C Tile Forum/Advice Board 26 05-24-2006 03:52 PM
Radius Bullnose or Bullnose - which do you prefer? socal_native Tile Forum/Advice Board 6 08-04-2005 09:23 PM
Which Method Is The Better Nikol Tile Forum/Advice Board 5 09-09-2003 07:00 PM
