Unread 07-15-2013, 05:29 PM   #1
abbythird
what type of Mortar for tiling 12x24 porcelian on Durock Next Gen W/ Redgard Membrane
hello everyone!
I am new to the forum, glad and very happy to found this forum.
I am about to install Durock Next Gen with Redgard waterproof membrane on surrounding bathroom walls, but was not sure which type of Mortar to use for tiling 12x24x3/8 Glazed porcelain. I want to be sure that it has good bonding.
Will Custom Building Products 50 lb. Marble and Granite Fortified Premium Mortar from Home Depot work?
Also, is there an alternative to Redgard waterproof/moisture barrier?
any suggestions is greatly appreciated.
Mike/Abby
Abby
abbythird is offline   Reply With Quote
Unread 07-15-2013, 07:49 PM   #2
Hi Abby. The marble and granite thinset works fine with porcelain tiles.
Mapei has Aquadefense and Laticrete has Hydroban.
Unread 07-15-2013, 08:03 PM   #3
There are also sheet membranes such as kerdi, dalseal, nobleseal....
Unread 07-15-2013, 10:11 PM   #4
abbythird
Thanks Dave,
Is there another thinset that will bonded well with big size porcelain?
Abby
Unread 07-15-2013, 10:12 PM   #5
abbythird
Thanks Houston
Abby
Unread 07-15-2013, 10:19 PM   #6
Abby, there are many dozens of thinset mortars available that will bond your porcelain tiles. Anything that says on the bag that it meets ANSI A118.1, or A118.4, or A118.11 has been tested for bond strength to porcelain tiles.
Some have higher bond strength than others. Some are easier to work with than others. Some cost more than others. Any one of them will hold your tiles on your wall very effectively.
Unread 07-15-2013, 10:40 PM   #7
Deckert
Versabond would be a fine choice, and its stocked at the Home Depots I'm familiar with.
Brannigan
HeenanGC.com
Unread 07-15-2013, 10:49 PM   #8
abbythird
CX, I read the other forum that a guy have the problem with bonding after applying REDGARD to the DUROCK NEXT GEN on his surrounding shower pan walls, but bonded perfectly with the area outside the shower in his bathroom.
is there a particular thinset that you would recommended?
Abby
Unread 07-16-2013, 09:03 AM   #9
Without knowing what problem "a guy" had or what mortar he was using, I can't comment on that, Abby.
Both your RedGard and Durock require a modified thinset mortar (A118.4) for bonding (not that un-modified wouldn't work), so chose one of those from whatever source is convenient to you. Custom Building Products (makers of the RedGard) makes several and some are available at your local home center. The VersaBond Deckert recommended is a good all-around choice.
Unread 07-16-2013, 09:22 AM   #10
abbythird
My error. The guy was using premix thinset and that is why it wasn't bonding with the tiles
Thanks again CX!:
Abby
Best type of mortar for bathroom tiling bsanders11 Tile Forum/Advice Board 8 08-12-2012 09:07 PM
durock next-gen AlpineVT Professionals' Hangout 48 04-07-2010 12:14 AM
Next Gen Durock Bill Vincent Professionals' Hangout 68 02-12-2010 06:16 PM
Durock Next Gen LAN1870 Professionals' Hangout 12 12-08-2008 08:04 PM
roll on membrane over Durock & mortar bed hunjuice Tile Forum/Advice Board 1 06-27-2005 01:15 PM
