Unread 05-11-2013, 12:45 PM   #1
joefar75
Mud or self-leveling?? Help !
ok.
Doing 700 sq ft of tile in a basement where the floor is off on Average 1/2" but as much as 1" in a small 4 sq ft area. I'd say average is 5/8". I have radiant under the existing concrete slab so Im a little weary about butting another 1.5 to 2.5" of mud.
But then on the other hand.. Im going to end up using a @#$*LOAD of self leveling; I'd estimate 40 bags @ $24 a bag.
Not sure which way to go?
or if there's another product that might be useful.
thanks in advance.
Joe
Joe
joefar75 is offline   Reply With Quote
Unread 05-11-2013, 02:04 PM   #2
add pea gravel to the SLC and your problem is solved.
most manufacturers will tell you how to use it.
Laticrete makes a new SLC called NXT LEVEL PLUS
Unread 05-11-2013, 02:32 PM   #3
joefar75
I was going to add the pea gravel to the area that were off by more than 1/2".... do you think I should add it when it's less?
Joe
Unread 05-11-2013, 03:15 PM   #4
you would need to call the manufacturers tech to ask that.
Unread 05-11-2013, 06:14 PM   #5
Ken
welchtile.com
My vote is for old fashion mud work... But that's only because I love to do mud work. SLC is too expensive for my blood. :-D
Also, just curious.. Why would you need to have the mud so deep? 2.5" to fix a floor in that condition seems a bit much from my perspective.
Ken
Ken is offline   Reply With Quote
Unread 05-11-2013, 07:55 PM   #6
ob1kanobee
ob1kanobee's Avatar
Is there a video on how to use the NXT from Laticrete?
Ben
Unread 05-11-2013, 08:11 PM   #7
joefar75
KURGON... I'd have to start with a min of 1.5" mud at the highest point, then there's about a 1" low point.... = 2.5"
Cant feather mud correct?
is there a way to build up the low point?
it's a small area... maybe 3' x 3'
Joe
Unread 05-11-2013, 09:54 PM   #8
ob1kanobee
ob1kanobee's Avatar
Just run screeds around the whole thing and through it (whatever) and dry-pack it. I'd trust that before SLC.
Ben
Unread 05-11-2013, 10:35 PM   #9
Tiling SB
Smile
Joe,
GO with the mud,
TCNA does not recommend feathering, but I believe you could go as thin as 3/4 with a bonded mortar bed.
You'll find plenty of help here to walk you through it
Oscar
Tiling SB is offline   Reply With Quote
Unread 05-12-2013, 05:10 AM   #10
ob1kanobee
ob1kanobee's Avatar
I don't quite understand the whole situation but where you are concerned about it being too thin you can cut the mud and stop it then feather it out with something else. I use stucco with thinset to adhere it for feathering, thinset only or whatever else I have laying around that will work.
Ben
Unread 05-12-2013, 05:54 AM   #11
Brad Denny
Tile Contractor Nashville, TN
Brad Denny's Avatar
Joe,
Concrete prep is always a joy.
The good thing, this isn't a heavy commercial traffic area so you have some liberties. The bad, it all costs money to get it right.
Consider a few points...
  1. With a bonded to concrete bed in a residential setting I would feel comfortable going as thin as .5" with a modified mortar bed as long as the areas aren't that big.
  2. With an SLC, you'd only have to fill the low points. As I understand, that shouldn't be that much (1" max), especially if you grind some.
  3. The "high" places. Are they so large that they couldn't be ground down a bit? Maybe worried about the radiant heating?
Brad
Unread 05-12-2013, 06:07 AM   #12
joefar75
Wow.... lots of help here. Thank you again. Can someone explain what a modified mortar Bed is? What's the correct mix for that?
Joe
Unread 05-12-2013, 06:16 AM   #13
Brad Denny
Brad Denny's Avatar
I was specifically thinking of this product, Joe...Laticrete 3701.
Brad
Unread 05-12-2013, 09:38 AM   #14
Tiling SB
Or you can modify it your self is cheaper this way
I usually mix 4 to 5 part all purpose sand, 1 part portland cement (also known as common cement) and add about 3 oz. Acrylic Mortar Admix to water to mix your mud.
Premixed stuff is Good, But I like to make my mud from scratch I got more control over the sand/ cement ratio
Oscar
Unread 05-12-2013, 03:03 PM   #15
MDtile
I'm not following why you need to float it up 1 1/2 - 2 1/2". If you just need it flat, you can use deck mud to a minimum depth of 1/4 -1/2" at the high point. Just notch a light coat of thin set to the slab and go to town while it is still wet. Or crack-iso 1st if your slab doesn't look too good.
A couple C metal cap strips work great for floating deck mud: nothing to fill after you pull them out. Just set them into the deck mud at your established height using a level and mallet, and you have instant screed strips to straight edge off of. Easy peasy and cheap too. Forget the self-leveling, you are not going to end up with a floor even close to being as flat as deck mud will give you.
MDtile is offline   Reply With Quote
Leveling a mud kitchen floor keithw Tile Forum/Advice Board 10 01-25-2010 08:33 PM
deck mud leveling tsquare Tile Forum/Advice Board 20 02-28-2007 11:52 PM
Leveling existing mud bed jml Tile Forum/Advice Board 4 10-09-2006 12:59 AM
Floor leveling mud failure: Now what? Laine MacTague Tile Forum/Advice Board 14 04-17-2006 05:02 PM
Leveling an Old Mud Bed brianp Tile Forum/Advice Board 2 08-09-2005 04:21 PM
