Unread 11-07-2012, 06:07 PM   #1
Keithett
New Bathroom remodel
I'm in the planning stages of a complete bathroom remodel and would like to replace the existing carpet and linoleum with tile. This is an upstairs floor consisting of 2X10 joints at 16" on center. The existing floor is 3/4" plywood, 1/2" sound board then 1/2" strand board.
I was planning on removing the 1/2" sound board and 1/2" strand board then replacing it with 1/2" exterior plywood and 1/4" wonder board. This would leave me room for my tile, thin set and under floor heating while maintaining a finish floor height close to the adjacent room. Does this sound like the correct way to go? I've been searching the internet but keep getting conflicting answers.
Thanks.
Keith
Keithett is offline   Reply With Quote
Unread 11-07-2012, 06:45 PM   #2
Welcome, Keith.
Yes, sounds good if you know the unsupported span of your floor joists and they meet the required L/360 deflection requirement and you install your second layer of plywood properly with the strength axis perpendicular to the joists and fasten it only to the first layer.
Unread 11-07-2012, 07:09 PM   #3
Keithett
Thanks for the quick reply... My span is 10' and when I use Deflecto to calculate the deflection, it says it easily works. I was planning on gluing and nailing the new plywood to the existing plywood so it would act as one piece. The orientation of the strong axis and not nailing into the joist is good advice and something I hadn't thought about.
Keith
Unread 11-07-2012, 09:40 PM   #4
I am a large proponent of gluing all parts of a subfloor structure, but gluing the subflooring panel layers must be done using a full spread of wood glue and a proper fastener schedule. You can't use any gun applied constructive adhesive for that operation.
Here's a good article about installing that second layer of plywood. Much of it may not apply to a small bathroom floor, but I would suggest you follow their recommendations to the extent that they apply. They do not recommend gluing the subflooring layers, but that's actually only because they fear you won't do it correctly.
Unread 11-26-2012, 10:00 AM   #5
Keithett
I have one other question concerning my tile project.
Am I better off following my original plan by replacing the existing sound board and strand board with 1/2" exterior plywood and 1/4" wonder board or would it be better to replace this with 3/4" plywood then use Schluter Ditra membrane on top of the plywood?
Schluter Ditra would give me the benefit of a waterproofing over the entire bathroom floor.
Keith
Unread 11-26-2012, 10:14 AM   #6
3/4" plywood will make your subfloor much stiffer than 1/2" plywood and backerboard. Otherwise, if both methods were installed properly, either would give you a long lasting tile installation.
Unread 04-15-2013, 07:06 PM   #7
Keithett
Recommened grout
I'm setting large format tile (12"x24") over Ditra in my bathroom. Does anyone have a recommendation on what grout I can use for this? Schluter recommends using a non-modified grout but I'm having problems finding a non-modified grout that will work. I'm planning on using a 1/2" x 1/2" trowel then back butter the tile.
Keith
Unread 04-15-2013, 07:27 PM   #8
Keithett
Sorry, I just realized I said I was looking for grout where I should have said mortar... What I'm looking for is a good quality mortar that I can use with Ditra.
Keith
Unread 04-15-2013, 07:58 PM   #9
cwilde72
cwilde72's Avatar
Ditraset and Laticrete 317 are my go-to unmodified's.
Chad Wilde
Precision Tile
Huron, SD
cwilde72 is offline   Reply With Quote
Unread 04-15-2013, 08:46 PM   #10
Lump
Lump's Avatar
I second the Ditra Set
Brad L. Lenz
NTCA Proud Member
Unread 04-16-2013, 02:06 PM   #11
Keithett
I've been calling around and Ditra Set is not sold by anyone in my area. I live in near Portland, Oregon.
I talked to the people at Laticrete and they don't recommend using Laticrete 317 for anything over a 1/4" thick bed. I see that HD sells CustomBlend but I've read in other threads that CustomBlend is not recommended with Ditra. Finding a good quality mortar for use under large format tile seems to be a problem. Any other suggestions?
Keith
Unread 04-16-2013, 03:46 PM   #12
Keithett
Maybe I'm over thinking this... I've already used Laticrete 317 to install the Kerdi and was planning on using it also to install the Ditra over SLC. Since my tile are very straight with little or no cupping, maybe I can just use a 1/4" x 3/8" trowel and back butter each tile. This would meet the Laticrete 317 requirements. Does this sound reasonable?
Keith
Unread 04-16-2013, 03:50 PM   #13
With an experienced hand that will work.
New bathroom remodel airplaneguy1 Tile Forum/Advice Board 38 02-20-2012 10:10 PM
First tile and remodel project - 9x12 bathroom remodel and 6x6 sauna kyle242gt Tile Forum/Advice Board 17 08-25-2011 08:42 AM
Bathroom Remodel Christian_dlP Tile Forum/Advice Board 3 07-05-2011 08:20 AM
My bathroom remodel sugaree53 Tile Forum/Advice Board 2 01-19-2011 12:45 PM
Bathroom remodel turracemsar Tile Forum/Advice Board 15 07-22-2004 06:05 PM
